Mosconi 6to8 DSP - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Classifieds Marketplace - Rules Strictly Enforced > Head Units, Processors & EQs
Head Units, Processors & EQs Head units, processors, equalizers and audio/video equipment go here.
Featured CACO Classified Ads
custom one of a kind...
by kn0wledge000
Old 03-21-2019, 08:12 PM
Brand New Members
0/11 ssssssss2
Default Mosconi 6to8 DSP
Mosconi 6to8 V8 DSP
Input Mode: Low Level {LL} / High Level {HL}
Input Imedance: > 10Kohm [Typ 14.3Kohm] (LL) / 37ohm (HL)
Input Sensitivity: 2Vrms 8Vrms (LL / 5Vrms 20Vrms (HL) – viaon-board potentiometers
Input Voltage Regulation: -12dB 0dB – via on-board potentiometers
Max Output Signal: 4Vrms
Output Imedance: 50 ohm
S/N Ratio: >102dB “A” (typ. 105dB “A”)
T.H.D. Distortion: <-0.003% @ 1Vrms
Frequency Response: 20Hz 20KHz (within -0.1dB)
Channel Separation: >91dB (@ 100Hz)
>91dB (@ 1KHz)
>72dB (@ 10KHz)
Supply Voltage: 11V 15V
Current Consumption: 0.5A @ 12V
DC-DC Converter: Transformer coupled, Voltage regulated, Current-Mode, Flyback converter
Conversion Frequency: 105KHz
Ground Isolation vs Car Body: 1Kohm (default) / Isolated (optional) / Grounded (optional)
Autosense: Two operative modes (yes, High Level mode only)
Remote Output: 130mA max
Communication Peripherals: On-board USB, Bluetooth socket, Remote controller connector for optional display-control unit
Expansion Slot: External Memory (EEprom)
Optical Board: Optional
Perfect working condition, although there is some material stuck on the bottom from what I believe was particle board (?) that the installers used to mount the DSP which is visible in the pics. It scrapes off pretty easily and may come completely clean with a little effort. I did not attempt to clean it at all.
$350 shipped to lower 48
Old 03-23-2019, 08:41 PM
Brand New Members
0/11 ssssssss2
bump!
Mosconi 6to8 with Bluebooth Module macming Head Units, Processors & EQs 5 08-07-2017 10:55 PM
Mosconi AS100.4 / Mosconi 4 to 6 DSP bigbrother54 General Car Audio Discussion & Questions 0 03-19-2015 03:48 PM
FS Mosconi 6to8 onebadmonte Head Units, Processors & EQs 3 08-14-2014 01:50 PM
Gladen/Mosconi 4to6 DSP bigbrother54 Head Units, Processors & EQs 2 06-07-2014 10:29 PM
MOSCONI 6to8 L a r r y General Car Audio Discussion & Questions 5 04-04-2014 02:56 PM
