Lanzar Opti 6k 732$ shipped onlinecarstereo - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Hot Deals From Around the Internet > Hot Deals
Hot Deals Online coupon codes, promotions, BOGO offers & whatever you find that will save our members money- on ANYTHING!!
Old 06-22-2014, 10:54 PM
0/11 ssssss118
Default Lanzar Opti 6k 732$ shipped onlinecarstereo
I couldn't resist I had to pick one of these up after seeing the internals this thing looks beefy and 46lbs?
Right now they are going for 779$ brand new with warranty from an authorized online dealer onlinecarstereo.com
Just use OCSAVE13 to get an extra 6% off your order, took mine down by 46.74$ to 732$ shipped
Linked this pic from
Opti 6k for different amp
The Following User Says Thank You to HelloImBob For This Useful Post:
cerwinvega_fan (06-22-2014)
Old 06-22-2014, 10:56 PM
0/11 ssssss535
I hope you get the amp. That site has been known to sell items they no longer have in stock and then make you wait for a refund.
Old 06-22-2014, 10:59 PM
0/11 ssssss118
Haha happened to me in back in 09 they had to cancel a mtx 9512-44....
Old 06-26-2014, 12:24 PM
0/11 sssss1090
how do you like it?
Old 06-26-2014, 01:00 PM
tv550's Avatar
0/11 sssss1658
Feedback Score: 37 reviews
Hopefully it doesn't go up in smoke like every other opti amp I've seen. Even with warranty it's a hassle.
Old 06-26-2014, 07:26 PM
0/11 ssssss118
Well funny story...They are out of stock on that amp too. So this thread is kind of useless now
I just wanted a temporary cheaper amp to still run 2 ss xxx-18s until I can find a truck/suv for a bigger system.
They wanted to upgrade me to the 7001d and I didnt like the 5k @ 1ohm 7k @ .5 ohm
The old amp sounded like a better deal to me because it was supposedly the same board as the ss xxx-10ks and as long as you had electrical down they did ok for cheaper than big name brand amp
My temporary cheaper amp turned into 1000$ lanzar amp...the 11001d says 10k @ 1ohm but Im reading the powersupply fails if you run a continuous 1 ohm
Oh yeah and only 2 power and ground inputs but calls for (4) 250 amp fuses, why dont they provide more inputs or dual input adapters with them if its needed
The way I see it without dual adapters its going to be (2) 300 amp fuses on 2 1/0 runs so Ill be maxed out at 600amps going in but i figure if I can manage a good clean 5k all day without it getting hot and without clipping subs then the ss xxx-18s should love every bit of 2.5k each
Now I just need a few new batteries to use it because mine are nice but too old and arn't holding a charge any longer so its time for new ones before the amp goes in. It may be a little while until I can use it.
EDIT::
Found some pictures of the internals on another forum so I uploaded them here too
Old 06-27-2014, 08:42 PM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2079
Feedback Score: 32 reviews
That is hot
Old 06-27-2014, 08:44 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
how are the Lanzar Opti's?
I see that they are rated at .5ohms
There's a BNIB 3k going for 250 shipped
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
Old 06-27-2014, 09:14 PM
0/11 ssssss177
Very similar board to many other common big boys, if you have the electrical to back it up, not the most efficient but make power. Don't run this on a factory electrical. I'm not a fan of online car stereo myself. Check Amazon they have had great deals on these in the past
Old 06-27-2014, 11:13 PM
0/11 ssssss118
Amazon is great but if you live in a state where they have tech centers and shipping locations you end up paying tax. I happen to live in one of those states :/
I am planning on trying to buy 3-4 batteries at costco without spending too much because Im already broke after just trying to buy a "temporary amp" until I can get the ab 1100.1 18v up and going that is just sitting on my floor
Will be run in a 07 dodge charger with DC XP270amp alt with a fiberglass box molded to the inside of the trunk in like 6 pieces then glasses together in the trunk and sealed around with greatstuff, only has (3) 6" ports right now because I only have 2 6x9 and 1 8" opening from the rear deck.
Planning on cutting my ports out to the 6x9s that the rear deck has and doing 2 6x9 ports and 1 8" port if I cant do 3 6x9 ports, I think I am going to cut some 6x9 rings of the inner diameter and roll some dual layer cardboard inside until its nice and smooth and then just soak it in fiberglass resin and install into box
Soon to be 2 SS XXX-18s in 11 cu ft-ish @ 35-ish on a lanzar opti 11001d hoping for a good clean 5k all day
It might be a few weeks but I will see about getting some pictures and results/opinions posted about this amp.
Lanzar opti 7k Twitney181 General Car Audio Discussion & Questions 11 05-14-2013 07:19 PM
WTB: Lanzar OPTI Scion or OPTI 4 channel amp beatnbronco Wanting to Buy (WTB) 0 11-12-2011 07:58 PM
Fs-Lanzar OPTI x-10 97maxima Head Units, Processors & EQs 3 05-19-2011 11:20 PM
lanzar opti 15? fiBl18 General Car Audio Discussion & Questions 7 01-14-2010 11:43 PM
considering Lanzar opti?......... tc3k101 General Car Audio Discussion & Questions 23 08-16-2009 10:57 PM
