Transition into the Incredible Hulk starring 6 PSI 18s,10k pls a little paint and fur - Car Audio Classifieds!
Old 09-20-2013, 02:45 PM
biscuit's Avatar
0/11 ssssss555
Default Transition into the Incredible Hulk starring 6 PSI 18s,10k pls a little paint and fur
Hey guys, havent been in i a while.. figured id start a teardown and rebuild thread... will have pics posted up shortly as soon as i get them sorted, lots of work has gone down and still have lots to go!
until then, here is a refresher of what i have. hope ya like
Biscuits mini rebuild/PSI inside!
The new rebuild took place from about june 4th to july 19th to make a Colorada show on July 20th
the build was completed in the matter of 4 and 1/2 weeks to make the colorado Usaci show that one of our guys was hosting, then made a few AZ trips for some MECA shows... currently the motor is on 6cyl status and coming out after this weeks CES show and sound comps... and then another full rebuild will begin!!!
Old 09-20-2013, 03:12 PM
biscuit's Avatar
0/11 ssssss555
heres some shots of some of the damage
and the beginning of teardown
driver side
passenger
The Following User Says Thank You to biscuit For This Useful Post:
iamsonic (09-20-2013)
Old 09-23-2013, 08:56 PM
KickinBlazer's Avatar
0/11 sssss1122
yep there is only so much sound pressure a vehicle can take before it just becomes a pile of metal on the floor....might i suggest welding everything up on the outside and smoothing and then add bracing and multiple layers of steel...or some unobtainium
if its to loud your to old!
Old 09-23-2013, 09:50 PM
biscuit's Avatar
0/11 ssssss555
pics coming soon
Old 09-23-2013, 11:12 PM
biscuit's Avatar
0/11 ssssss555
And the teardown and repair begins!
found alot more rips and tears once i pulled it apart
Old 09-23-2013, 11:29 PM
biscuit's Avatar
0/11 ssssss555
and time for a bit of surgery, let the stitching begin!
Old 01-04-2014, 09:53 PM
biscuit's Avatar
0/11 ssssss555
Here goes in on the bodywork!
and now we have primer!!!
i did not want to overload and bore you guys with all the individual dings and dents repaired..
iamsonic (01-04-2014)
Old 01-04-2014, 10:07 PM
biscuit's Avatar
0/11 ssssss555
several body work sessions, recating and resurfacing to get as much as right as possible... literally hundreds of hours in bodywork alone...
before and after ex
and yes all done in my home garage
all taped up and time to jamm!!
Old 01-04-2014, 10:13 PM
biscuit's Avatar
0/11 ssssss555
time for another wet sand and smooth before the real paint goes on
and paint goes on!!
time for some clear and pearls
https://fbcdn-sphotos-d-a.akamaihd.n...04465458_o.jpg
SINTORMAN (01-04-2014)
Old 01-04-2014, 10:34 PM
biscuit's Avatar
0/11 ssssss555
time for some trim shots!
2 PSI pf 2 18s dual 2ohm disturbeddrummer254 18" Subwoofers 7 08-22-2013 06:05 PM
2 PAP/PSI 18s for Something Different Gpro1194 Car Audio Trader (WTT) 6 03-31-2013 12:52 AM
FS (2) PSI Platform3 18s - Dual 1s Decaf 18" Subwoofers 11 12-21-2011 11:07 PM
5 Sundown 4500s on 10 PSI 18s 98HOEONSIXEZ Car Audio Videos 34 12-11-2011 05:27 PM
