2012 Toyota 4Runner build - Car Audio Classifieds!
Old 04-21-2016, 08:25 PM
lowcel's Avatar
Country Boy
0/11 sssssss45
Default 2012 Toyota 4Runner build
Thought I would take a couple of minutes to share my 4Runner. It is a work in progress that began about three months ago. I'm a new return to the hobby so I am learning as I go. All work in the vehicle has been performed by me.
Head unit - Kenwood DDX372bt
DSP - Helix
DSP Controller - Director
High Amp - Zapco Z 150.6 LX
Sub Amp - Zapco Z1KD
Subs - (3) JL Audio 12W3v3's
Highs - PPI P65C3
Alarm - Viper 3305v w/ backup battery, glass breakage sensor, back up siren
Custom pillars housing the tweeters.
Dash speakers.
Door speakers and some deadening.
More deadening.
Director installed in the sunglasses compartment.
Speaker wire and temp controller area.
Power / ground area.
The goodies.
The Following User Says Thank You to lowcel For This Useful Post:
Chris McNeeley (04-21-2016)
Old 04-21-2016, 09:58 PM
0/11 sssssss35
Thats some sick work man
The Following User Says Thank You to Anthony123 For This Useful Post:
lowcel (04-22-2016)
Old 04-22-2016, 11:06 AM
Mecp_advanced's Avatar
0/11 sssssss73
Nice install You should come show my local JL Dealer how to do it right lol
The Following User Says Thank You to Mecp_advanced For This Useful Post:
lowcel (04-22-2016)
Old 04-22-2016, 03:23 PM
aqlover's Avatar
0/11 ssssss737
Nice clean install right there
What is this ES-PEE-EL you speak of?
The Following User Says Thank You to aqlover For This Useful Post:
lowcel (04-22-2016)
Old 04-22-2016, 04:02 PM
lowcel's Avatar
Country Boy
0/11 sssssss45
Thanks guys, I appreciate it. I've worked my ass off on it.
Old 04-22-2016, 05:05 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Very nice...
Sent From My Phone
Old 04-22-2016, 07:09 PM
lowcel's Avatar
Country Boy
0/11 sssssss45
Originally Posted by jigsizzle View Post
Very nice...
Sent From My Phone
Thank you.
Today I worked on a few more little details. After all, it's all in the details...
First off, I got rid of the phillips head screws holding the barrier strips. I used threaded brass inserts and security torx screws.
Inserts...
Torx screws...
Next I put a little velcro between the two speaker cover panels. This tightens it up a hair but more importantly it blocks the light from showing up between the panels.
Before.
Now. I'll get a better picture with the lights on later.
Last but not lease I made a little demostration board to show most of the wiring I used as well as hardware that I've used.
Old 04-22-2016, 07:22 PM
lowcel's Avatar
Country Boy
0/11 sssssss45
A few more details.
Security torx screws holding the distribution / fuse blocks.
Techflex covered siren wires.
Security torx screws holding siren. This was prior to coving the wires.
Threaded inserts for amps and dsp.
Security screws for dsp.
Security screws for amps.
Power wires covered in techflex and heat shrink.
All alarm wires soldered.
All alarm wires looking factory after install.
Alarm back up battery.
Speaker wires wrapped in techflex, identified by different color electrical tape.
A picture of my glass of water that froze up while I was working on the install.
Installing rivet nuts.
Picture of me wishing I had a garage.
Old 04-25-2016, 09:12 AM
lowcel's Avatar
Country Boy
0/11 sssssss45
Not a bad Weekend at Springfest in Ohio, a triple points MECA show. Third place SQ Street. First place Street Install. Best of Show Install.
I'm happy.
Old 04-28-2016, 03:52 PM
lowcel's Avatar
Country Boy
0/11 sssssss45
New speakers installed in the doors and factory dash locations. Now I just need to do some tuning.
Audible Physics speakers are just so damn pretty!!!
highpsicobra (05-21-2016)
GiGLZ 04 Toyota Echo 2012 Build GiGLZ Miscellaneous Build Logs 4 07-08-2012 05:45 PM
toyota 4runner mechman 220a alt bre2ts Wiring, Electrical & Other Installation Equipment 12 02-15-2012 02:47 AM
3" body lift for 1990-1995 toyota 4runner bre2ts Miscellaneous Stuff For Sale 3 01-23-2012 12:25 PM
2000 Toyota 4Runner bumpin buick Uninterrupted Build Logs 4 10-08-2009 09:45 PM
2000 Toyota 4runner bumpin buick Build Logs 20 08-06-2008 11:08 AM
