2014 gmc sierra z71 aka ruby. Lift, performance, and audio - Car Audio Classifieds!
Old 05-01-2016, 08:50 PM
0/11 ssssss337
Talking 2014 gmc sierra z71 aka ruby. Lift, performance, and audio
The link below will take you to a playlist outlining all the mods done to the truck, after the lift. It was installed in a local shop. Everything else was installed by me.
7.5" mcgaughys lift
35" toyo open country MT's
20X9 -12 OFFSET DPR wheels
Road Armor Prerunner Bumper
Smittybilt XRC 12k
Rigid Industries Dually Pods (fog and spot)
Offbrand 22" led bar
Flowmaster Super 10 American thunder cat back
Dual battery setup ran with 0/1
Optima Yellowtop secondary battery
Big 3 of course, stock alt.
Digital Designs DD M3B
Digital Designs DD1508's D4's -1ohm
Ported box front firing side port.
0/1 to the m3b.
Yes I plan on doing my mids next, not sure what route to go.
If you're just interested in the audio, check the last video.
Thanks.
Watch "2014 Gmc Sierra Z71 build log -Ruby" on YouTube
2014 Gmc Sierra Z71 build log -Ruby: http://www.youtube.com/playlist?list..._GF0fqhD0UWR9Z
We got two bodies in the morgue that look like they were
"serial crushed by some huge friggin' guy!"
Old 05-01-2016, 09:03 PM
0/11 sssss1070
the mcguaghy lift and toyo mt's are expensive, but the right way to go i hear. good to invest money into the long term when it comes to suspension lol i bet you had some issues with rubbing though with that offset. unfortunately our GM's come with fancy square wheel wells.
Old 05-01-2016, 09:20 PM
0/11 ssssss337
Actually no rubbing at all!
The only time I have rubbed is when I'm out in the mud, and I hit a big hole, if my wheels are turned they do hit a bit, but not enough to notice. Thanks yeah I figured the mcgaughys have been making lowering kits since the late 80's, so they have alotta R&D in GM trucks, so figured I couldn't go wrong. They actually drop the entire suspension 7.5", not a 5" like the RCX kits I see. I can actually turn my struts up, to get to 9" of lift, and add a leaf in the back to clear 37's but I like the straight cv angles and the cheaper, and less weight 35's. Thanks man. She's my dream truck. Not sure what to do for the mids tho.
Old 05-01-2016, 09:58 PM
0/11 sssss1070
depends on what size, how many, if you'll be adding some sort of digital sound processing, running active, budget, goal of sq/spl etc.
Old 05-01-2016, 11:10 PM
0/11 ssssss337
Well, I want to keep my factory touchscreen, I was planning on adding a processer, and just removing the line out converter I currently ran to get some bass. Wanting to stick with DD they are local to oklahoma, and I wanna keep it that way with them.
I was considering swapping my 6x9's in my front doors with 6.5 mid bass drivers, doing the same in the rear and tweets in the front. Amps will have to be mounted behind the back seat. Thinking 50-75rms on the mids per speaker.. somethin like that.
Tags
z71 digital designs m3b 1508
Truck Owners GTFIH (GMC Sierra) T3mpest General Car Audio Discussion & Questions 10 03-13-2015 11:07 AM
Zavala_90s GMC Sierra build log Zavala_90 Miscellaneous Build Logs 1 01-25-2014 11:56 AM
2008 GMC Sierra Quad 2500HD Old Bump Build Logs 3 12-06-2013 05:27 PM
1998 4x4 GMC Sierra Build 98GMC Build Logs 19 03-18-2011 07:57 PM
Wtb kick panels 99 gmc Sierra Jesus805 Wanting to Buy (WTB) 1 12-21-2010 12:10 PM
