PHATBOi's 07 CVPI 2 15 4th Rear Deck Blow Thru - Car Audio Classifieds!
Old 11-23-2016, 07:25 AM
PHATBOi's Avatar
0/11 ssssss829
Default PHATBOi's 07 CVPI 2 15 4th Rear Deck Blow Thru
What's up CACO? Been a min since I posted, so I figured I'd show y'all my current setup. Car is an 07 retired Bradenton Police Department P71 Crown Vic. Setup is a 2 15 4th order rear deck blow thru, built by my team and I. Shout out to Team Heavyweight, and our design/build department at Soundpressure Designs, for all the help.
Had 2 Crescendo Contralto D4 15's on a FSD FZ3800 at 1 ohm. Was only clamping 1541 watt out of the amp wired to 1, rising to 3.4. So, I ordered a set of Sundown X15 v.2 D2 to drop her down to .5 and get a little more power.
Did a 147.21 at 31Hz on the dash, driver's door and trunk open (I run ISPLL Subsonic Suicide so that's how I meter).
Team Heavyweight
Old 11-23-2016, 09:39 AM
PHATBOi's Avatar
0/11 ssssss829
https://youtu.be/Fg6lLWUaHgA
Team Heavyweight
Old 11-23-2016, 09:58 AM
massivespl's Avatar
0/11 sssss8409
Subsonic suicide at 30hz? Shouldnt u be playing like 20hz? Lol gotta get them extra points
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 11-23-2016, 10:12 AM
PHATBOi's Avatar
0/11 ssssss829
It's 32 and under. You get .25 dB bonus for each frequency under 32. I peak at 30/31 so that's where I play.
Team Heavyweight
Old 11-30-2016, 09:01 PM
PHATBOi's Avatar
0/11 ssssss829
https://youtu.be/qt_OHDnj9tM
Team Heavyweight
Old 11-30-2016, 11:28 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Yeah for real massive. I don't feel like a real basshead unless I've burped 16hz at 160 for at least 5 hours.
team graham
Ideas on 4th order or blow threw back deck dirtysouth basshead General Car Audio Discussion & Questions 9 07-07-2014 08:16 AM
2010 Impala 4th order rear deck blowthrough FLAstrongman Build Logs 67 06-24-2014 01:08 PM
Rear Window blow through. 3:1 4th order ridintwo6s Build Logs 13 06-09-2013 12:48 PM
4th order ported thru rear deck lexus ls400 tha1027455 Enclosure Discussion & Design Construction Help 3 03-17-2012 07:50 PM
Port through rear deck, 4th order? Jh8909 Enclosure Discussion & Design Construction Help 11 02-06-2010 01:10 AM
