Amp cooling modification. - Car Audio Classifieds!
Old 08-12-2011, 03:08 PM
0/11 sssss4519
Default Amp cooling modification.
So the Florida eat is scorching this year so before I decide to hookup the Goliath I am adding some cooling. I took the back plate off and cut out a new one. Drilled a ton of holes ranging from 3 to 7 on my 1"" step bit and installed an [email protected] 120mm fan. Thing moves a ton of air for it's size and is damn near impossible to hear.
However I do need to install a few spacers and raise the back plate about 2mm up because it's very close to touching some stuff in the amp
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 08-12-2011, 03:16 PM
0/11 ssssss954
nice work man. and i feel you on the fl heat. everytime i pop my trunk everything is hot. but that may be from running it full tilt. who knows lmao
Old 08-12-2011, 03:18 PM
0/11 ssssss954
oh and be careful cuz i had one like this and it fried eventually.
Old 08-12-2011, 03:38 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
purty sweeet !!
the torroid cores put out a lot of heat !! i think thats what their called
this amp in pic is broke but i wanna clip this fan an do sumthin similar to my 2.4k,
ill probly do sumthin like what you did, great idea, maybe run it off of a relay or a switch on the dash, or even a thermistor type switch lol
anyways good work
Old 08-12-2011, 03:40 PM
0/11 ssssss954
no just run it off ur amps ground and remote
Old 08-12-2011, 03:45 PM
sthrnbumpn's Avatar
0/11 sssss2961
i could do that, i just want to add sumthing a little different too it
Old 08-12-2011, 03:50 PM
Jokerr's Avatar
0/11 sssss2279
Feedback Score: 33 reviews
DO NOT run it off your remote unless you have a relay!
I buy blown amps,
Old 08-12-2011, 03:52 PM
0/11 ssssss954
thought it was obvious lol
Old 08-12-2011, 04:14 PM
sthrnbumpn's Avatar
0/11 sssss2961
whats the worst that could happen ?
i wouldnt do that just wondering what the consequences would be?
not to be jacking lyfer, but was wondering thats all
Old 08-12-2011, 04:54 PM
Jokerr's Avatar
0/11 sssss2279
You can't pull any amperage whatsoever through a remote wire, you will fry the hu
I buy blown amps,
will this amp rack affect amp cooling? MERQUE General Car Audio Discussion & Questions 11 03-06-2011 07:43 PM
Questions about amp cooling and big circuits. mattintc10 General Car Audio Discussion & Questions 26 03-03-2011 04:34 PM
Amp cooling Fly ty 215 General Car Audio Discussion & Questions 0 02-27-2011 05:01 PM
amp getting too hot..LF liquid cooling bobbygilly General Car Audio Discussion & Questions 20 10-04-2010 03:51 AM
amp cooling? slamnride General Car Audio Discussion & Questions 9 07-30-2009 01:06 PM
