Xbox 360 Repaint - Car Audio Classifieds!
Old 06-01-2009, 01:12 AM
Prohibited Sellers/Buyers
0/11 sssss6709
Feedback Score: 17 reviews
Default Xbox 360 Repaint
Started May 29th , 2009: this May Well guy's i orignally got this xbox 360 from obrien on here with RROD(Red Ring of Death) I went and fixed it but i went a step further and since i found one really cheap i went and replaced the whole disc drive. Yes i did it w/o flashing the drive i have secrets haha. But i was bored one day and was getting sick of lookn at the white plain cover. So i went and tapped off all the necessary holes etc....and here's how it came out to be not bad if i say so myself. I plan on painting the controllers also to match.
1st coat of Metallic Silver.
Showing the back piece , was even made sure to tape off all the orignal labeling just for hell of it lol.
On the final coat , but no clear coat on it yet.
Final metallic coat on with almost last coat of clear on now.
All metallic coats sprayed & Coats of clear on and drying sadly my camera does not show the clear coat it's justice.
How it sit's now. Also like said plan on painting controllers to match.
Old 06-01-2009, 01:14 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
nice
92 Ranger Walkthrough
(Under Construction)
Old 06-01-2009, 01:15 AM
0/11 sssss6709
Thanks bro once the controllers i paint look even better. Plan on doing controllers same metallic silver with the silver stripe that will be flat black also to match the bottom/top pieces.
Old 06-01-2009, 01:20 AM
obrien202's Avatar
I race dertscooters
0/11 sssss4142
Feedback Score: 26 reviews
very nice bro, glad it got fixed up right and everything
may music always make you happy even if life does not
Old 06-01-2009, 01:24 AM
0/11 sssss6709
ThX bro yeah man i took it apart a couple times just because i wanted to make it better each time haha.
Old 08-12-2009, 03:46 AM
TheJesus's Avatar
Yawning
0/11 sssss1921
Looks pretty good, I still think you need to do some flashing of that drive :P. And you need to cut a window and liquid cool it, lmao
Old 11-23-2009, 01:05 AM
0/11 ssssss267
Interesting since the dvd drive wont work without flashing it with the correct key.
Nice Case though
Team D.O.A.
97 Mercury Grand Marquis LS
Deck: Alpine CDA-9887 (Active)
Speaker Amp: American Bass SQ780
Front Stage: Image Dynamics CTX65CS
Sub Amp: Sundown SAZ-2000
Sub Stage: 2 Sundown SA-10s D4
Box:
4th Order (2.5 Ported, 1.0 Sealed, 41Hz) 80INCHES Design
Wire: Knu 1/0 Amp Kit and Big Three
Deadening: 55+sqft Dynamat Xtreme (Front Doors, Rear Lid, Trunk)
TL Score: New Setup Unknown (141.6 Old)
Old 12-02-2009, 08:58 PM
0/11 sssss6709
This 360 in the work's again guy's taking all apart once done here's what it will consist of.
All clear casing (Including driver cover etc....)
Having tails fan in back lit up blue l.e.d.
XCM cooler v2 also lit up blue l.e.d.'s
Wait to ya see her when she's done.
Old 12-14-2009, 07:46 PM
jprix82's Avatar
0/11 ssssss150
Looks great! DId you have to use plastic specific paint?
Old 01-16-2010, 03:16 AM
0/11 sssss6709
Update: Janurary 16th , 2010 well guy's i got bored today since my work cut hrs short. But i was gonna do all clear casing but being i don't got that kind of cash i went a diff route.
The cooling is two xcm fans
tailwhisper fans to replace two stock fans
Aftermarket heatsinks over chips.
Here's an update. lmk what you guy's think sry for crappy night pics best could get though.
What i also plan on doing adding blue l.e.d's also to the left hand side to match the right , changing out the ring to also be blue , paint the controller cases to match and whatever else i may think of haha. Lmk what you guy's think.
Original XBOX russhay78 Car Audio Trader (WTT) 2 04-12-2009 03:18 PM
Xbox 360 canyouhearmatt Miscellaneous Stuff For Sale 8 02-06-2009 10:47 PM
Wtt: Xbox 360 for 15'' sub s Beatz Car Audio Trader (WTT) 6 12-28-2008 01:02 AM
