The reason I havent been on CACO much - Car Audio Classifieds!
Old 03-14-2012, 02:23 AM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Default The reason I havent been on CACO much
Well on my way to work I managed to blow my motor and tranny so heres whats going on
Freshened 400 sbc with a 700R4 to come.
Vortec heads, sitting at about 10.5:1 SCR. Cam is in the air, thinking 288/288 dur. .480 lift and a 108 LSA. Heads will get LS6 valve springs, new valve seats and new retainers and steam holes drilled. Should be good up to .525 of lift.
Using a Procomp intake, Holley 650 cfm carb, HEI dizzy, and Moroso wires.
Trip home
Two guys, no hoist but we did it
Heads off. Clean for its age.
Little paint dont Worry, pan is changing.
Procomp MLS head Gasket. Need to get my RA in spec.
Wrong heads and valve covers but it's a teaser
More to come
Old 03-20-2012, 01:20 PM
0/11 sssss6190
Changed up the cam. Running the Summit SUM-1103. Didnt really want to change torque converter. Should still have a little lope with good street manors.
Fresh Cloyes Timing set, Summit Cam button and cam lock kit
One Piece rubber pan gasket, summit oil pump pick up and sealed power oil pump
Nummy, fresh pan and timing chain cover
Heres the other 400 Ive been working on in my buddies truck:
Cammed (unknown specs but she moves!)
Edelbrock intake
Holley 650 CFM vac secondaries
rubber valve cover gaskets and valve covers are fresh
Old 03-20-2012, 01:29 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
lookin good man, keep it up
Old 03-20-2012, 04:48 PM
0/11 sssss6190
Thanks man!
Old 03-27-2012, 11:13 AM
0/11 sssss6190
Scrapped the Vortec idea. Clean up on the heads
Offenhauser intake. My friend hooked me up huge
Cleaned up a set of Moroso Valve covers. Now i need a set of T handles
Why i havent touch car audio in months linden Off Topic Chat 10 06-23-2011 10:31 AM
This is the reason... madmat Off Topic Chat 16 04-21-2009 05:43 PM
THE reason to by JL nismos14 General Car Audio Discussion & Questions 2 10-07-2008 08:41 AM
The reason... s Beatz Off Topic Chat 5 08-29-2008 10:41 AM
