4th order band pass - Car Audio Classifieds!
Old 05-18-2012, 10:51 AM
Jtasaro's Avatar
0/11 sssssss73
Default 4th order band pass
I built my first 4th order band pass a while back a thought I would post the pictures from the build...can't remember the specs but the woofer I chose was a B2 audio es8 their entry level 8 inch sub box turned out great I had a friend draw up the plans box hits a wide range and sounds excellent
ImageUploadedByTapatalk1337352235.298230.jpgImageUploadedByTapatalk1337352287.327151.jpgImageUploadedByTapatalk1337352333.371862.jpgImageUploadedByTapatalk1337352373.879641.jpgImageUploadedByTapatalk1337352423.366825.jpgImageUploadedByTapatalk1337352538.919203.jpgImageUploadedByTapatalk1337352631.885572.jpgImageUploadedByTapatalk1337352675.037155.jpg
How do you band pass in active set up? SKDooley General Car Audio Discussion & Questions 4 02-14-2012 03:58 AM
4th order or 6th order kingtidis Enclosure Discussion & Design Construction Help 5 05-30-2011 12:05 AM
