2010 Malibu Shok Build - Car Audio Classifieds!
Old 06-14-2012, 12:10 PM
ThisGuy31's Avatar
0/11 sssssss36
Default 2010 Malibu Shok Build
Hey everybody! Figured I'd start a build log to keep track of my progress since my build is now about 70% finished. This is my first online build log, but not my first build. Big thanks to Sound Specialists and Team Excessive members Toby and Nate for their help on the build. And also thanks to Russ from Shok Industries for making great products. Now that the a** kissing is done, on to the build...
We started by removing the stock battery seen here with old power and grounds.
Team Shok
Team Excessive
Old 06-14-2012, 12:13 PM
ThisGuy31's Avatar
0/11 sssssss36
After the old battery was removed we needed to modify the stock battery tray to accommodate the larger AGM.
Team Shok
Team Excessive
Old 06-14-2012, 12:24 PM
ThisGuy31's Avatar
0/11 sssssss36
We started upgrading the charging system by doing the "big 3". We used some 1/0 Monster Cable removed from the previous install and Techflexed it to match all of the Shok wire that was soon to go in.
Team Shok
Team Excessive
Old 06-14-2012, 12:36 PM
ThisGuy31's Avatar
0/11 sssssss36
With all of the factory wires and upgrades tacked to the side posts the fuse holders were mounted to the factory electrical box and triple 1/0 top post installed on the battery.
Team Shok
Team Excessive
Old 06-14-2012, 12:49 PM
ThisGuy31's Avatar
0/11 sssssss36
Toby Holding the positive runs of Shok Reference Elite about to go in.
With all of the interior on the driver's side removed we were able to start running the 6 runs through the firewall. All runs were Techflexed in the engine bay and coming in through the firewall. Back-up camera wires along with RCA's were relocated later on to avoid signal interference.
Team Shok
Team Excessive
Old 06-14-2012, 12:57 PM
ThisGuy31's Avatar
0/11 sssssss36
Wires were secured through firewall using silicone and tacked every 8" throughout the entire vehicle.
Team Shok
Team Excessive
Old 06-14-2012, 12:59 PM
mcmuffin's Avatar
0/11 sssss3380
lookin good bro. u can post more than 1 pic per post tho lol
*** NEW BUILD COMING SOON ***
its a secret for now
The Following User Says Thank You to mcmuffin For This Useful Post:
dcollister440 (07-27-2012)
Old 06-14-2012, 01:03 PM
ThisGuy31's Avatar
0/11 sssssss36
Haha, I know just trying to get the post count up. It's all good. I'll start doing one post per section of the build after I get the wiring job posted.
Team Shok
Team Excessive
Old 06-14-2012, 01:24 PM
ThisGuy31's Avatar
0/11 sssssss36
Fuses installed in back by factory fuse panel in trunk.
Picture of completed wiring job under hood
Team Shok
Team Excessive
Old 06-14-2012, 02:26 PM
ThisGuy31's Avatar
0/11 sssssss36
2 layers of Second Skin Damplifier Pro were applied to the trunk and rear deck. All factory holes were covered. 100% coverage on all metal panels.
Then Second Skin Luxury Liner was applied to all plastic panels so that the plastic panels set flush against metal. Factory insulation was thin enough that it could be placed over the Luxury Liner.
Team Shok
Team Excessive
VVX15" '99 Chevy Malibu trunk build vISUALHype Build Logs 0 04-05-2012 01:35 AM
05 Malibu. Tear down and Re-build. DC and RF slapuhho Build Logs 136 10-10-2010 02:07 PM
pieper's Malibu Build Pieper Build Logs 0 04-13-2010 10:41 AM
Team Shok 2010 headshok (Shok Ind) 15 01-12-2010 04:16 PM
Shok Industries--- coming soon--- 2010 products headshok (Shok Ind) 38 12-07-2009 03:18 AM
