GiGLZ 04 Toyota Echo 2012 Build - Car Audio Classifieds!
Old 06-18-2012, 04:01 AM
GiGLZ's Avatar
0/11 ssssss514
Default GiGLZ 04 Toyota Echo 2012 Build
Welp...here it is... First major setup which took me 5 x 8hr days in total..
Won myself first place in Stock Pro 1 for my first competition.
145.0dbs sealed
Some of the pictures of the build got jumbled...sorry
1 x 15" Custom Sub
50ft 4/0 DLO Cable
2 x Planet Audio BB2400.1 Strapped
5 cubes tuned .. well.. variable.. 51 hz, 46 hz, 41 hz, 35 hz..
2 x deep cycle batts in rear
1 x yellowtop in front
4/0 ANL Fuse holders
AudioControl Concert Series Line Driver
AudioControl Epic-160
First off.. The motor.. MACK 3ton w/ inverted neo top plate.
Heavy bish!
Ressurecting the MTX RFL 152 Beast!
Side by side comparisions.. From left to right: MMATS P3.0 12", one of my GiGLZ 10" Rebuilds, and new beast.
Hand Stitching more leads to these Sundown Audio z.3 Spiders. Thumbs were like tenderized meat by the end of it..
Chopped up a perfectly good 12" cone assembly to use with a salvaged surround from the RFL
RFL Coil compared to new 70mm coil.. extra long former.
Now.. The box.. Built to 5 cubes tuned to 51hz.. Everything crisp and square.
... Worked out great, but didnt get the 63hz rise I was hoping..
... Other pieces of the puzzle...
2 x batts for the rear..
4/0 DLO Cable.. Tinned Copper.
Buncha 4/0 ring terminals.. Ended up buying 16 then another 10 later had to torch these puppies on.
Batts in rear with some wiring done..
First Amp wired up
Box in now.. Had to rip out front seats to fit this bad boy in.
2nd amp in now.
Burndy 4/0 to 1/0 Reducers to wire to my amps
Extra large ANL Fuse Holders.. can hold upto 4/0 Wiring
Yellowtop under the hood... Some of the wiring done..
Old 06-19-2012, 03:54 PM
GiGLZ's Avatar
0/11 ssssss514
guess nobody likes the build?.. was looking for any suggestions to get louder
Old 06-19-2012, 04:51 PM
GiGLZ's Avatar
0/11 ssssss514
can someone help move this thread to misc build? thx
Old 06-20-2012, 02:28 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
very interesting sub, I love the custom work you put into it man
Old 07-08-2012, 05:45 PM
GiGLZ's Avatar
0/11 ssssss514
Sorry for the delay.. The full excursion is seen more when camera is farther away from subwoofer near the end of the clip.
GiGLZ M.A.C.K. Custom 15" RFL Excursion - YouTube
1988 toyota build astrolade Build Logs 52 02-15-2016 09:12 AM
1988 Toyota Truck Build RidnClean Build Logs 41 02-15-2016 09:06 AM
Toyota Corolla Focal Build Chuck Build Logs 2 01-26-2012 02:54 PM
Wtb alt for 2000 toyota echo CRACKERJACK Wanting to Buy (WTB) 12 01-11-2010 11:55 PM
Toyota Truck Build w/dd1508 PlugItIn Build Logs 17 11-03-2009 10:07 PM
