Makeover for the expo - Car Audio Classifieds!
Old 04-21-2013, 11:50 PM
0/11 ssssss623
Default Makeover for the expo
Well guys, I'm sure some of you may have seen my previous build. Its been quite awhile. Didn't keep the system for long. Had to make some comprimises. Sold everything I had and bought a house. That was a little over a year ago. Projects never end. The wife wants me to ease up on getting a system so I've been slowly gathering for the last 6 months.
I currently have a single 18" tc9 based sub. Freshly built no box yet. Plans with be 8 cuz ft 4th order after displacements. According to winisd it will play from 23hz through 72hz with authority. Sub will be ran off an old school mm4k. Just need to repair the output section.
The front stage is nothing special. May be lacking but for now, who cares. Factory premium ford 6x8. They will be powered by a pierce audio emp amp. 45rms x4 @4 ohms if I remember correctly. Tweeters will be 8 gm delco's ran off another emp amp. Like I said nothing great.
I've ripped out my center console and started to mod my spare to fit the 2 pierce audio amps into the arm rest. Got almost finished with that and decided to just make my own center console amp rack. Amp rack is still in the works and won't be anything great. I get very little time to work on it. It will house 2 pierce audio 4 channel amps, an mm4k amp, and 1-2 batteries. If I'm lucky I may be able to squeeze in a tray to hold crap as well. Only have 1 battery for right now.
As for a head unit, I've got a clarion eq that I will be using along with my cell phone for music for the time being. I will eventually be running a 9-10" tablet but figured I can use my phone for the time being and I should spend the money else where. I have 3 eBay digital volt meters. There tiny! Nothing special.
And now for some pics.
Old 04-22-2013, 10:46 AM
0/11 ssssss623
This is where I`m at today.
have to make an additional piece to support another battery.
The explorer got a makeover! 46panel Car Audio Videos 26 06-29-2011 05:03 PM
Expo... RidnClean Team NWSPL 29 02-17-2011 05:06 AM
Ridnclean's Expo RidnClean Member Rides & System Pictures 41 11-04-2009 04:29 PM
E8 Makeover worstenemy453 (Fix My Speaker) 21 07-27-2009 09:51 PM
