2010 Ford escape - 2-12inch NS - 5000watts - Car Audio Classifieds!
Old 06-17-2013, 06:07 PM
0/11 sssssss19
Default 2010 Ford escape - 2-12inch NS - 5000watts
Hey guys I am back and this time with a new vehicle! it is a Ford Escape 2010, v6 3.0 litre.
The setup is:
2-12inch NS v1
2-SAZ2500
2-NSB90's
A little bit about me I am now working with Arctic Combustion and I am a travelling service tech and I do any and all things related to boilers!
So here is what I have to work with: 63x41, but after my tools on 33x41, and the 41 can go to 52 max, the wheel wells put me at 41"
Here is the machine! it is a tan colour and yes there is a after market security system already installed (hench the blue light).
So the jack was in an interesting spot, so it got moved
batteries - NSB 90's
Here are all the tools I have!
Here is all the left over space I have for a sub stage, I expect to use about 50% of it up. That stuff currently there isn't normally there.
I plan to wire those batteries up this friday and I plan to use a stinger line out converter. so that way I keep my original dash and the sync features!
and yes I know subs are useless in a work vehicle but I don't plan on a big setup, I will end up going to a single 12 in the future but for now and while I have space I will go all out!
Old 06-17-2013, 06:08 PM
0/11 sssssss19
so please note the above post was done a few month back and everything has changed since then!
Old 06-17-2013, 06:16 PM
0/11 sssssss19
so it seems I have been lazy on this build! I guess time flys when you are busy! at any rate we seemed to slow down a bit at work so I now have some progress to post!
here is the new way I store all my tools
here is what is under the back floor mat, lots of room for amps!
sadly the battery is about 1/2" to tall, so I will mount that behind the box and ontop of the false floor
first floor
please note the din rail! and relay! I found those at my shop and put them to good use! although I am short 2 more terminal blocks for my sub.
second floor! I see an upgrade to 3500 in my future!
wiring
[IMG]http://i138.photobucket.com/albums/q269/CcCrazy/2010%20Ford%20escape/IMG_20130616_131324_zps9ad11337.jpg
false floor fitting, this will be replaced with 3/4" birch, the 1/2" is only temporary to get the shape!
the box!*
dinner after a long day of farting around!
all that is left for me to do is:
get a new starting battery, one with posts and screws
get a new H/U something double din, any suggestions?
cut out the false floor using 3/4" birch
redesign tool storage!
Help Me Decide! Ford Escape or Ford Explorer? Raptor660 General Car Audio Discussion & Questions 31 07-21-2012 08:30 AM
Ford Escape Esoteric Build Logs 12 01-23-2012 04:26 PM
2010 ford escape 99Bonney General Car Audio Discussion & Questions 1 03-26-2011 08:48 PM
alt for 2010 ford escape hybrid 99Bonney General Car Audio Discussion & Questions 1 02-08-2011 09:05 AM
2005 ford escape Toone General Car Audio Discussion & Questions 1 09-13-2010 05:25 PM
