x18 trunk build - Car Audio Classifieds!
Old 09-16-2014, 08:53 PM
0/11 sssss1237
Default x18 trunk build
not much to say here, couple pictures,
going to do baffle tomorrow then bought fiberglass resin for the inside, two coats should do it and make it nice and glassy.
going to do complete inside, then put top on and finish fiberglassing so i can get around those corners easy,
no curfed ports here or any fancy angling besides the front baffle, my trunks opening only allows 17.5 inches, so i had to make a 73.6 degree slant for the baffle which should also help in a nice sound quality standpoint to fit the x18 in snuggly
sub and amp still on way, maybe monday or tuesday they will be here.
amp audiopipe gp6001d
sundown x-18
3/4 " birch
2" gold screw
*pre drilled first
2 Sundown X18 & 2 MB Quart DSC1500.1D Build PHATBOi Build Logs 95 06-28-2014 08:34 PM
Trunk build... rear deck vs. sealed trunk regizzle General Car Audio Discussion & Questions 9 04-12-2013 05:09 PM
trunk build help undergroundminis1 General Car Audio Discussion & Questions 12 12-26-2012 05:36 PM
Future Trunk Build GPCustoms Enclosure Discussion & Design Construction Help 5 10-22-2012 05:09 PM
Solo X18 in a trunk: Has it been done with good results? 1ndatrunk Enclosure Discussion & Design Construction Help 30 07-08-2010 10:00 AM
