xcort wall build - Car Audio Classifieds!
Old 02-22-2010, 11:34 AM
mega fatty
0/11 sssss6008
Default xcort wall build
95 ford excort
18 apxxd2 16cf wall
rd d9
2 stinger sp1700's, 3 spv70's
170amp alt
well alt and one sp1700 are already in, yeah i got a sp1700 up front, and i have one run of 1/0 to the back batt bank
box build starts NOW!
box 16cf internal, interchangeable ports, 320sq" of port tuned to 65, 180sq" tuned to 39
Tear down
^potential problem input on this?
the new wing!
Old 02-22-2010, 01:22 PM
mega fatty
0/11 sssss6008
new design! little better port will be 27tallx12widex3long to tune to 53hz for burps
Old 02-22-2010, 01:35 PM
dak446's Avatar
0/11 sssss5914
Very nice. Thas a big box for one sub lol but if I were you, I'd cut that piece out that's corroded and rusted and weld it up w/ some 3/8" steel,and never look at it again lol. But you could probably scrub it up w/ a wire brush and get it clean, then spray some anti-rust primer/paint on it, to keep it from continuing to corrode.
Old 02-22-2010, 01:42 PM
mega fatty
0/11 sssss6008
i like the way you think on the paint i dont think ima weld it... the car will be a daily driver until i get a new car then its just a toy!
i talked to super-stanny on termpro and he said they work amazing in 16cf for walls
plus im making the regular port for daily a bit on the small side hopfully that will keep the sub from bottoming out at lower frequencys
i still gotta figure out the best way to secure the walls to the bottom and top because it will be assembled in the car, im for sure using glue but to hold it until it dries? maybe use the angle screw thing on them so i can put the screws in on a angle and they sit flush.
Old 02-22-2010, 04:07 PM
mega fatty
0/11 sssss6008
the monster drill bit!!!
rear batts going here^
Old 02-22-2010, 04:10 PM
mega fatty
0/11 sssss6008
oh yeah and i cut all the rusted stuff out, sanded it all good paint and great stuff over it!
Old 02-22-2010, 04:16 PM
twistedchild420's Avatar
MR.SQ
0/11 sssss5537
Lookin good man! 16 cubes seems like a shit ton though! Vids soon i hope!
Old 02-22-2010, 04:18 PM
luises14's Avatar
Loyal Member
0/11 sssss2531
Feedback Score: 30 reviews
looks good I built my box inside the car too and glue really doesnt hold to well mostly because you can't clamp well enough untill it dries, what worked for me was fiberglass resin it dries pretty fast(if you put alot of hardener) and soaks into the mdf great
Old 02-22-2010, 04:31 PM
0/11 sssss5305
Diggin the new wing...
I assume you use a scraper or short hair paint brush to spread the glue so the entire 2x4 or panel is covered. MUCH better adhesion that way.
Old 02-22-2010, 04:57 PM
0/11 sssss5305
I've built numerous walls inside cars/suv's and glue holds fine. use plenty of screws to pull the panels tight while the glue dries and also plan out the cuts/assembly so you can reach every place that needs to be screwed...
Jacob's Wall Build Log sundownz (Sundown Audio) 114 07-12-2011 07:08 PM
92 s-10 ex. cab wall build s10 with 4 15's Build Logs 86 09-27-2010 04:11 PM
xcort wall build tymoto21 Uninterrupted Build Logs 5 03-31-2010 02:50 PM
Frontier kinda wall, 2 AQ SDC 15's build log Goindef154 Build Logs 26 07-06-2009 02:40 AM
2000 mercury cougar wall build basebalz13 Build Logs 81 02-07-2009 10:33 PM
