Team Red Stick Boat Build - Car Audio Classifieds!
Old 07-11-2011, 09:52 PM
0/11 sssss7816
Default Team Red Stick Boat Build
Thats right *****es.
We're building a boat.
This site is a few days behind on my log, so heres some catchup.
Boat specs:
Design length* * * * *:* * *15.880 [ft]
Length over all* * * *:* * *14.880 [ft]
Design beam* * * * * *:* * * 4.576 [ft]
Beam over all* * * * *:* * * 4.571 [ft]
Design draft* * * * * :* * * 0.250 [ft]
Midship location* * * :* * * 7.940 [ft]
Volume properties:
* * Displaced volume* * * * * * * * * * * *:* * * * 10.381 [ft3]
* * Displacement* * * * * * * * * * * * * *:* * * * *0.297 [tons]
* * Total length of submerged body* * * * *:* * * * 12.302 [ft]
* * Total beam of submerged body* * * * * *:* * * * *4.251 [ft]
* * Block coefficient* * * * * * * * * * * :* * * * 0.7941
* * Prismatic coefficient* * * * * * * * * :* * * * 0.8154
* * Vert. prismatic coefficient* * * * * * :* * * * 0.8702
* * Wetted surface area* * * * * * * * * * :* * * * 52.756 [ft2]
* * Longitudinal center of buoyancy* * * * :* * * * *7.054 [ft]
* * Longitudinal center of buoyancy* * * * :* * * * -7.205 [%]
* * Vertical center of buoyancy* * * * * * :* * * * *0.134 [ft]
Midship properties:
* * Midship section area* * * * * * * * * *:* * * * *1.035 [ft2]
* * Midship coefficient* * * * * * * * * * :* * * * 0.9739
Waterplane properties:
* * Length on waterline* * * * * * * * * * :* * * * 12.302 [ft]
* * Beam on waterline* * * * * * * * * * * :* * * * *4.251 [ft]
* * Waterplane area* * * * * * * * * * * * :* * * * 47.718 [ft2]
* * Waterplane coefficient* * * * * * * * *:* * * * 0.9126
* * Waterplane center of floatation* * * * :* * * * *7.652 [ft]
* * Entrance angle* * * * * * * * * * * * *:* * * * 48.779 [degr.]
* * Transverse moment of inertia* * * * * *:* * * * 67.095 [ft4]
* * Longitudinal moment of inertia* * * * *:* * * * 518.68 [ft4]
Initial stability:
* * Transverse metacentric height* * * * * :* * * * *6.597 [ft]
* * Longitudinal metacentric height* * * * :* * * * 50.101 [ft]
Lateral plane:
* * Lateral area* * * * * * * * * * * * * *:* * * * *2.721 [ft2]
* * Longitudinal center of effort* * * * * :* * * * *7.553 [ft]
* * Vertical center of effort* * * * * * * :* * * * *0.133 [ft]
Atomic Loudspeakers
Audiotechnix
Old 07-11-2011, 09:53 PM
0/11 sssss7816
Rough renderings, on the first image, the white part is the part that will be under water at* the designed 3" draft.
Atomic Loudspeakers
Audiotechnix
Old 07-11-2011, 09:54 PM
0/11 sssss7816
Bottom of the boat is done.
Atomic Loudspeakers
Audiotechnix
Old 07-11-2011, 09:55 PM
0/11 sssss7816
Things are shaping up.
Atomic Loudspeakers
Audiotechnix
0/11 sssss7816
Commence scarfing action.
Laid out
What better to clamp with than speaker boxes?
Atomic Loudspeakers
Audiotechnix
Old 07-11-2011, 09:56 PM
0/11 sssss7816
Tommorow gets transom and filleting.
Atomic Loudspeakers
Audiotechnix
Old 07-11-2011, 09:57 PM
0/11 sssss7816
Bad picture, but, transom is in, almost completely filleted from the inside, and back stringers/deck support system in.
Atomic Loudspeakers
Audiotechnix
0/11 sssss7816
And, we're up to speed.
Atomic Loudspeakers
Audiotechnix
Old 07-12-2011, 11:54 AM
98AckCL23's Avatar
0/11 sssss9929
Shit's weak...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 07-12-2011, 12:01 PM
Prohibited Sellers/Buyers
0/11 sssss1326
Laid out
whats that blue box wrapped in? i want some.
Leave her or stick with it? 1-12-t1 Powder Room 42 07-22-2011 04:01 PM
Boat Stereo? Boat FLEX? 350 Fuel Injected Engine? Winter's 24' Chaparal Sunesta 233! twistedchild420 Car Audio Videos 3 04-02-2011 10:35 PM
Boat Build [email protected] Build Logs 7 03-05-2011 12:03 PM
People playing music off a USB stick Tehbannage General Car Audio Discussion & Questions 27 12-17-2010 11:16 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 09:44 PM
