BNIB Taramps HD15000 - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Classifieds Marketplace - Rules Strictly Enforced > Amplifiers > Mono Amplifiers
Mono Amplifiers Mono amplifiers go here.
Old 06-03-2019, 04:58 PM
maverickdog8's Avatar
0/11 sssss2979
Default BNIB Taramps HD15000
BNIB Taramps HD15000 with triple 4/0 terminals
-Number of Channels: 01
-Max. Output Power @ 14,4 VDC - 1 OHM: 15.000W RMS
-Max. Output Power @ 14,4 VDC - 2 OHMS: 10.920W RMS
-Input Sensitivity: 230mV @ -13,15 dBm
-Signal Noise/Ratio: ˃95dB
-Full Range Frequency Response: -3dB @ 10Hz to 10KHz
-Crossover High Pass (HPF): 10Hz to 80Hz (-12dB/Oct) Variable
-Crossover Low Pass (LPF): 80Hz to 10KHz (-12dB/Oct) Variable
-Input Impedance: 18K OHMS
-Protection System: Short-Circuit to Output / High / Low Supply Voltage - Thermal Protection
-Minimum Supply Voltage: 9 VDC
-Maximum Supply Voltage: 16,5 VDC
-Idle Consumption @ 14,40 VDC: 3,60 A
-Maximum Musical Consumption @ 14,40 VDC: 648,5 A
-Consumo Maximo Senoidal @ 14,40 VDC: 1.297,1 A
-Dimensions(LxAxP): 268 x 72 x 519mm
-Weight: 8Kg
BNIB.
SOLD!!
Old 06-03-2019, 04:59 PM
0/11 sssss2979
Old 06-05-2019, 02:29 PM
0/11 sssss2979
Price is OBO!! I will be at Slam this weekend if someone is interested I can bring it with.
Old 06-05-2019, 10:54 PM
0/11 sssss2979
If anyone is interested I will be at Slamology and can bring this amp with. Will do a $825 cash price at Slam!
Old 06-12-2019, 11:14 PM
0/11 sssss2979
Bump.
Old 06-14-2019, 05:22 PM
0/11 sssss2979
$850 shipped price drop.
Old 06-20-2019, 07:58 AM
0/11 sssss2979
Bump
Old 07-17-2019, 10:55 AM
0/11 sssss2979
Bump.
Old 07-17-2019, 06:35 PM
0/11 sssss2979
SOLD!!!!
