Arc Audio 400.4 - Car Audio Classifieds!
Old 06-22-2012, 07:14 PM
Ricksi30's Avatar
0/11 ssssss997
Default Arc Audio 400.4
1. Product: Arc Audio 400x4
Rated Output Power (RMS):
50 watts x 4 @ 4 ohms
100 watts x 4 @ 2 ohms
190 watts x 2 @ 4 ohms bridged
Transient distortion: less than 0.05% @ 4 or 2 ohms
Frequency response: 20 Hz-20 KHz
S/N ratio(A wtg): greater than 95 dB
Bass boost: + 18 dB @45 Hz
Crossover: 55 Hz-5.5 KHz variable 12 dB
Fuse: 40A x1
3. Description/Condition: Used works great. Cosmetics are 7/10 due to some scratches.
4. Price: :165 shipped.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 06-23-2012, 07:11 PM
Ricksi30's Avatar
0/11 ssssss997
Bump!
Team SSA
Old 06-25-2012, 02:41 AM
Ricksi30's Avatar
0/11 ssssss997
Bump.
Team SSA
Old 06-25-2012, 02:41 PM
Ricksi30's Avatar
0/11 ssssss997
Bump.
Team SSA
Old 06-26-2012, 05:33 AM
theunderfighter's Avatar
0/11 ssssss158
2 questions: Is this active capable? Do you have the dimensions?
HU- Kenwood eXcelon KDC-X994
Fronts- Crescendo mids and Vifa Ring Radiator tweets on ARC Audio KS300.4
Subs- Single SA-10 on Mmats 2000.1 @ 1
Misc- Big 3 in Stinger HPM, Power wire AT 1/0 CCA, and AT 60 mil deadener
Old 06-26-2012, 06:13 PM
Ricksi30's Avatar
0/11 ssssss997
The crossover can be set LP/HP from 50-550 on two channels, and LP/HP 50-5500 on two channels. I'll post the dimensions asap.
Team SSA
Old 06-26-2012, 06:29 PM
Mr.G6's Avatar
0/11 sssss4614
its not active capable a active 4 channel amp has a bandpass setting
(from what i read)
2000 Gmc Sonoma ext cab
Old 06-26-2012, 10:41 PM
Ricksi30's Avatar
0/11 ssssss997
(from what i read)
Correct it can't bandpass.
Team SSA
Old 06-27-2012, 05:54 PM
Ricksi30's Avatar
0/11 ssssss997
Buuuump
Team SSA
Old 06-27-2012, 10:31 PM
Ricksi30's Avatar
0/11 ssssss997
130 shipped!!
Team SSA
bnib arc audio arc 8d4 Nudels 8" Subwoofers 2 05-24-2012 12:29 AM
LNIB: Arc Audio Arc 8s stylez12321 8" Subwoofers 3 01-10-2012 12:19 AM
FS Arc Audio sotelomichael Multi-channel Amplifiers 1 04-23-2011 10:14 PM
FS: Arc Audio MX-3 1blualti Head Units, Processors & EQs 0 12-13-2010 02:43 PM
