Alpine MRV-407 4 Channel Amplifier - Car Audio Classifieds!
Old 06-30-2012, 06:15 PM
newarkbeast973's Avatar
0/11 sssss7810
Default Alpine MRV-407 4 Channel Amplifier
Title.
If you need a very solid amp for cheap and that will be hidden this is the amp for you!!!
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20kHz)
MRV-F407 (CH-1 CH-4)
Per channel into 4 ohms ........................... 40W, 0.08% THD
Per channel into 2 ohms ............................ 50W, 0.3% THD
Bridged into 4 ohms ................................ 100W, 0.3% THD
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20KHz)
Per channel into 4 ohms ........................... 60W, 0.08% THD
Per channel into 2 ohms ............................ 80W, 0.3% THD
Bridged into 4 ohms ................................ 160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 ohms ............................................ 120W
Bridged into 4 ohms .................................................. 320W
Frequency Response ................... 10 Hz to 50 kHz (+0, 1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 105 dBA
Slew factor .................................................. ...... Greater than 5
Damping factor
MRV-F407 ................................................ Greater than 100
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ....................................... Line in: 10k ohms<
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and Slope
MRV-F407 ............. 50 Hz to 400 Hz x 20, 12 dB per octave
Power Requirement .................. 11 16V DC Negative Ground
Dimensions (W x H x D)
MRV-F407 ............................... 260mm x 60mm x 330mm
(10-3/16" x 2-3/8" x 13")
Weight
MRV-F407 ........................................ 5.3 kg (11 lbs. 10 oz)
A little beat up. 5/10 physical but 100% working condition.
$60 shipped
New build coming soon!!
Old 07-01-2012, 10:55 AM
0/11 sssss7810
Up!!!!
Old 07-02-2012, 04:44 AM
0/11 sssss7810
Up!!!
Old 07-02-2012, 12:19 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Damn. I just got one off Ebay but it was for the MRV-303
Old 07-02-2012, 12:51 PM
sBass Audio's Avatar
Sonic Boom Auto Sound Src
0/11 ssssss663
pm sent
Old 07-02-2012, 04:09 PM
0/11 sssss7810
Sold...
FS : Used Alpine MRV-407 4 Channel Amplifier skaraudio Multi-channel Amplifiers 4 06-03-2012 01:01 PM
old school alpine v12 mrv-1000 and mrv-f300s and rare link!!!!! usampsman Car Audio Packages 8 04-30-2011 12:11 AM
FS: Alpine mrv-f545 4 channel amp bgaccord Multi-channel Amplifiers 7 09-01-2010 05:38 PM
Alpine MRV-F409 Multi-Channel Amplifier Special Edition with Copper Bottom kmorales3 Multi-channel Amplifiers 5 06-21-2010 12:14 PM
ALPINE V12 MRV-F303 4 channel AMP! Great shape! $75 shipped OBO! tahoebrotha Multi-channel Amplifiers 0 01-02-2009 07:20 PM
