[SOLD]MTX 4300x - Car Audio Classifieds!
Old 09-16-2008, 01:15 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Default [SOLD]MTX 4300x
4300x is $175 shipped Good shape
RMS Power measured at 12.5 Volts DC:
37.5 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
85 Watts x 4 into a 4 Ohm load
140 Watts x 4 into a 2 Ohm load
280 Watts bridged x 2 into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm) Including IsoFeet(TM)
My Car, My Ears.
Old 09-17-2008, 02:41 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
package with these subs
FS: 2 IB 10's
Exodus DPL-10's XBL2 300 rms
$140 shipped
  • Fs: 23 Hz
  • Re: 6.5 Ohms
  • Qms: 4.7
  • Qes: .91
  • Qts: 0.76
  • Mms: 99g
  • Cms: 0.47 mm/N
  • Vas: 73L
  • Sd: 333 cm^2
  • Vd: 1.26L
  • BL: 10.2
  • X-max: 19mm
  • Pmax: 300W
  • SPL: 81.7 db/1W/1M
you can run the fronts of this amp to a comp set and bridge the rear to these subs. $300 for the package shipped.
My Car, My Ears.
Old 01-10-2010, 06:07 AM
0/11 ssssssss6
Default need that mtx 4300x
Need to buy that amp bro!! what's your number??
Sym (284)542-3281
Old 01-10-2010, 06:34 AM
0/11 sssss1917
Sym (284)542-3281
SERIOUSLY?!?!
Look at the OP date.
Old 01-10-2010, 06:38 AM
0/11 ssssssss6
Default My Bad
did'nt look at it!! that sucks, do you no any one who has anything like that? 4200X, 4300X ......
Old 01-10-2010, 06:50 AM
No, I'm not dead
0/11 sssss8128
Post a WTB thread. FYI though, this IS nismos we're talking about so it's very possible he still has this. As far as I'm aware, he closes his threads when the item's gone although he may have missed this... at least there's a possibility it's still here.
Old 01-10-2010, 07:12 AM
0/11 ssssssss6
he reponded and told me he does not have it. thanks madmat
Old 01-10-2010, 09:52 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
I never responded lol, but I think newarkbeast73 has my old one for sale.
My Car, My Ears.
Old 01-10-2010, 09:53 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Here you go FS: Old school Goodness!!! - Car Audio Classifieds
My Car, My Ears.
