Polk Audio PA660 w/manual, harness, mounting hardware - Car Audio Classifieds!
Old 08-23-2012, 06:17 PM
0/11 ssssss104
Post Polk Audio PA660 w/manual, harness, mounting hardware
1. Product: ^^^^^
75 x 4 rms @ 4 ohms
85 X 4 rms @ 2 ohms
150 x 2 rms @ 4 ohms bridged
Other specs and info can be found in this excellent review.
10/10 functional and cosmetic condition. Everything works and looks great.
$80 shipped
Old 08-23-2012, 07:26 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
trades?
Old 08-23-2012, 07:43 PM
0/11 ssssss104
I'd take a 2 channel amp doing 150 x 2 or better at 2 ohms. It needs to be small though, no bigger than the PA660.
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
intreast in an mb quart 4,60 or sslw4.500?
Old 08-23-2012, 07:53 PM
0/11 ssssss104
I don't think that MB is stable @ 2 ohms bridged (I'd like more than 120 watts/channel @ 2). I haven't heard of the sslw4.500, details?
Old 08-23-2012, 07:55 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
RMS Power:
70Watt x 4 Channel @ 4 Ohm
110 Watt x 4 Channel @ 2 Ohm
500 Watt MAX
Gloss Black Finish w/ Brushed Accents
Mosfet Pulse Width Modulated Power Supply
IDI Intelignet Distress Indicator (short, thermal & overload protecion)
Tri-Mode Capable
Delayed On/Off Circuit
10-35KHz Frequency Response
105dB Signal-to-Noise Ratio
0.02% Total Harmonic Distortion
>250 Damping Factor
200mV-6V Input Sensitivity
0,6,12dB 50Hz Bass Boost
Input Selection
High Level Input
Direct Wire 4 ga. Power, 8 ga. Speaker Terminals
Dimensions: 11.42"L x 9.45"W x 2.52"H
Old 08-23-2012, 08:04 PM
0/11 ssssss104
That sounds like a nice amp but again, probably not stable @ 2 ohms bridged and doesn't put out enough power for me not bridged.
Old 08-23-2012, 09:38 PM
0/11 ssssss473
Default trade
i have a sound stream its 150 rms per channel 2 ohm stable
Old 08-23-2012, 10:18 PM
0/11 ssssss104
No thanks. Actually I'll also consider a 4 channel amp doing at least 75x4 @ 2 ohms that I can use for a 2 way active setup (mids and tweets).
Old 08-25-2012, 04:54 PM
Awaiting Confirmation
0/11 ssssss120
payment sent
Cerwin Vega Vega 154's!!! 1kw, svc, 15" with ORIGINAL mounting hardware! o. l. t. 15" Subwoofers 12 04-23-2012 11:25 PM
Polk PA660 spm_215 Multi-channel Amplifiers 8 01-09-2012 05:27 PM
Polk Audio PA660 4 Channel 98GCLimited Multi-channel Amplifiers 19 10-07-2011 05:11 PM
Box building & subwoofer mounting hardware doug118 Enclosure Discussion & Design Construction Help 4 05-25-2011 12:26 PM
Boston Neo 4t Tweeter Mounting Hardware BassAddictJ Speaker Accessories & Parts 1 03-04-2011 09:03 PM
