Eclipse ea4200 - Car Audio Classifieds!
Old 09-10-2012, 11:32 PM
perfecxionx's Avatar
0/11 ssssss225
Default Eclipse ea4200
Eclipse ea4200, 4channel class d full range
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (70 watts RMS x 4 at 2 ohms)
140 watts RMS x 2 bridged output at 4 ohms
CEA-2006 compliant
variable high- and low-pass filter (30-500 Hz, 18 dB/octave)
variable bass boost (0-8 dB at 45 Hz)
subsonic filter (18 Hz, 18 dB/octave)
two sets of preamp-level inputs, one set of preamp outs
full-range Class-D amplifier design
MOSFET power supply
fuse rating: 30A x 1
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
10-1/4"W x 2-3/8"H x 7-11/16"D
theres 1 or 2 small scratches on it, id say 9.5/10 cosmetically, 10/10 functionally
One of the low-high filter switch ends snapped off, it still works, but you need to use a small screwdriver (or something) to switch it(easy). I included a photo of this
If someone buys this along with my mb quart dsc1500 ill sell both for 132 plus shipping!!
80 shipped to CON US
Old 09-12-2012, 12:46 PM
0/11 ssssss225
perfect for small footprint projects
Old 09-13-2012, 02:58 PM
0/11 ssssss225
removing the chrome end caps narrows it to a smaller width, so if you dont have alot of space this is the amp for you
Old 09-14-2012, 10:16 PM
0/11 ssssss225
sadfasdfasdfsafd
Old 09-17-2012, 02:47 AM
0/11 ssssss225
80 shipped
Old 09-19-2012, 02:25 PM
0/11 ssssss225
ill do 132+shipping if someone buys both amps
FS) 2 New Eclipse 8808 8" subs & 2 New Eclipse XA1000 Amps brirat Car Audio Packages 0 05-11-2011 03:27 PM
Mint Condition Eclipse EA4200 4ch. Amplifier Marvelous Marv Multi-channel Amplifiers 2 02-14-2011 01:57 AM
Eclipse EA4200 Amp killa101 Multi-channel Amplifiers 1 08-31-2010 01:24 AM
Eclispe EA4200 Service Manual? shogi3480 General Car Audio Discussion & Questions 0 08-25-2010 11:34 AM
differences from Eclipse 88120ti dvc and Eclipse SW9122??? nefariouscaine General Car Audio Discussion & Questions 5 08-18-2010 05:41 PM
