Sundown SAX-100.4 - Car Audio Classifieds!
Old 10-09-2012, 04:23 PM
n8skow's Avatar
0/11 sssss1519
Default Sundown SAX-100.4D
Sundown SAX-100.4D
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Variable Subsonic Filter
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Rated power output
RMS power, 4 ohm stereo
100W x 4CH
RMS power, 2 ohm stereo
160W x 4CH
RMS power, 4 ohm bridged
320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
[email protected] Watts <0.1%
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
a few nicks and scratches, but not beat up
$250 shipped continental US
As far as trades, I'd only be interested in a few specific items:
10" SoloX SPAIRS ('04 grey style)
10" L7's ('08 or '11 models)
Memphis 16-MC4.75 amp
Alpine PDX-F4 amp
Short Ram air intake for a Toyota
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
Old 10-10-2012, 11:09 AM
n8skow's Avatar
0/11 sssss1519
bump...
Old 10-11-2012, 12:09 AM
n8skow's Avatar
0/11 sssss1519
*-sale is pending-*
Tags
100.4, 4 channel, sax, sundown
Like new Sundown SAX-100.4 bvdogg Multi-channel Amplifiers 8 10-05-2012 04:10 PM
Sundown SAX 100.4 jws84_02 Multi-channel Amplifiers 10 05-22-2011 09:04 PM
Sundown SAX 100.2, 125.2, or 100.4D 240FAP Wanting to Buy (WTB) 6 09-04-2010 09:39 PM
WTB Sundown SAX 125.2, 100.2, 100.4 ClickClickBoom Wanting to Buy (WTB) 15 06-08-2010 05:24 PM
[TRADED] Sundown SAX 100.4 for SAX 125.2 or 100.2 plus a little $$ groundpound4200 Car Audio Trader (WTT) 25 06-03-2010 12:55 AM
