FS: Polk PAD5000.5 (3-way active!) - Car Audio Classifieds!
Old 11-04-2012, 05:49 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
Default FS: Polk PAD5000.5 (3-way active!)
1. Product: Polk audio PAD 5000.5
  • PA Series 5-Channel Class D Car Amplifier
  • RMS Power Rating:
    • 4 ohms: 70 watts x 4 chan. + 200 watts x 1 chan.
    • 2 ohms: 100 watts x 4 chan. + 400 watts x 1 chan.
    • Bridged, 4 ohms: 200 watts x 2 chan.
    • Subwoofer Channel (1 ohms): 500 watts x 1 chan.
  • High-speed MOSFET power supply
  • Wired remote bass level control included
  • Efficient design to help amplifier run much cooler than conventional amps
  • Toroidal transformers ensuring plenty of clean, efficient power and a compact size
  • LED power (green) and protect (red) indicators
  • Soft Start Turn-on
  • Stable at 2 ohms for full range channels and 1 ohm at subwoofer channel
  • SUB/INT source switch for cleaner signal processing
  • Chanel Mode switch that sends same signal to front and rear channels
  • Non corroding stainless steel hardware for a sturdier look and feel
  • 5/4/3 channel operation
  • 4-Way System Protection circuitry (thermal, DC offset, reverse DC voltage, and short circuit protection)
  • Heavy duty aluminum alloy heatsink for extreme heat dissipation
  • Nickel-plated RCA level inputs
  • Nickel-plated screw terminals
  • Input sensitivity:
    • Low level: 200V-6V
  • Variable high-pass filter (40-400 Hz, 12dB/octave)
  • Variable low-pass filter (80-4,000 Hz, 12dB/octave)
  • CEA-2006 compliant amplifier
  • Frequency response: 20-20,000 Hz
  • Dimensions: 13-5/16"L x 6-3/4"W x 1-13/16"H IT IS LITTLE!
3. Description/Condition: Used but in AMAZING condition. been used for about two months now. needing more power at 4ohm then it has on the sub channel.
4. Price: : $280 Shipped and insured. Will throw in two 1/0 to 4awg toolmaker inputs with the amplifier
Old 11-05-2012, 12:38 PM
DonH's Avatar
0/11 sssss6645
active ready! this thing sounds great too
Old 11-09-2012, 12:45 PM
DonH's Avatar
0/11 sssss6645
bump .
Old 11-10-2012, 01:47 PM
DonH's Avatar
0/11 sssss6645
tttttttttt
Old 01-12-2013, 03:18 PM
DonH's Avatar
0/11 sssss6645
i still have this if anyone is interested
Old 01-14-2013, 01:39 PM
DonH's Avatar
0/11 sssss6645
bump up
Old 01-26-2013, 03:13 PM
DonH's Avatar
0/11 sssss6645
tttttttt
Old 01-31-2013, 10:19 PM
DonH's Avatar
0/11 sssss6645
price drop! $250 shipped and insured! LIKE NEW!
Old 02-02-2013, 12:14 PM
DonH's Avatar
0/11 sssss6645
tttttttt
Old 02-06-2013, 04:24 PM
DonH's Avatar
0/11 sssss6645
bumpsters
Polk midbass Russellabt Car Audio Trader (WTT) 1 04-30-2012 08:47 PM
Polk Pa1100.5 SpringfieldOhio Multi-channel Amplifiers 32 09-29-2011 08:25 PM
polk db 6.5 components bikerdc17 Component & Coaxial Speakers 0 09-09-2011 09:26 AM
FS Polk MM571 USED $50 OrionStang Component & Coaxial Speakers 0 07-19-2011 02:25 AM
Clarion DXZ785USB 3 way active / 2 way active + sub deck. nismos14 Head Units, Processors & EQs 8 07-11-2011 09:27 AM
