Viper Audio (Directed) 1100.5 Rare 5-Channel Amplifier NIB - Car Audio Classifieds!
Old 01-21-2013, 01:06 AM
0/11 sssssss92
Viper Audio 1100.5
http://www.directed.com/guides/manua...io/G1100_5.pdf
Dual high-speed MOSFET switching power supplies and complimentary bipolar outputs on 1-4 with a high current MOSFET output on the sub channel
Thermal, DC offset, reverse polarity, short circuit and over/under voltage protection with status LED
Easily accessed top-mounted controls for system tuning located under illuminated Viper snake logo
Built-in high performance, dual continuously variable 12 dB/octave 2-way active crossovers on channels 1-4
Continuously variable 24 dB/octave low-pass crossover on sub channel
Variable 0-12 dB bass EQ function
Remote subwoofer level control
2/4/6 channel input for full access to source or processor output functions
Master/slave function allows external synced bridged or parallel operation with an added model d600.1 class D mono amp
Buffered stereo full-range RCA output jacks
Gold-plated power and speaker screw-block plugs and RCA connectors ensure maximum signal transfer
Rugged one-piece extruded heat sink finished with injection-molded mounting feet
Rated Power @ 4 ohm: 75 x 4 (ch1-4)
Rated Power @ 4 ohm: 275 x 1 (sub)
Rated Power @ 2 ohm: 125 x 4 (ch1-4)
Rated Power @ 2 ohm: 400 x 1 (sub)
Rated Power @ 1 ohm: N/A (ch1-4)
Rated Power @ 1 ohm: 600 x 1 (sub)
S/N: > 95 dB (ch1-4)
S/N: > 80 dB (sub)
Freq. Range: 20-20 kHz (ch1-4)
Freq. Range: 20-250 Hz (sub)
Damping Factor: > 100 (ch1-4)
Damping Factor: > 50 (sub)
Input Sensitivity: 150mV to 8V
Crossover: var. 12dB 2-way (ch1-4) (They can be high passed from 50hz to 500hz)
Crossover: var. 24dB low-pass (sub)
RCA Output: Stereo (ch1-4)
RCA Output: Mono (sub)
Mechanical: 10/10
Physical: 9.5/10
I purchased this amp in 2004 but sold my 4Runner soon after and never got around to installing. It was one of the best 5 channel models available for my needs at the time so have been reluctant to sell in the hopes I'd eventually get an opportunity to use it. My current vehicle doesn't have enough room so I'd like someone else to enjoy this great amp.
It's still in the original box and has never been turned on since I don't have a way of testing the unit. I guarantee it works and will accept a return with full refund if any problems arise when first powering up, as long as you do so within a few months.
It's in excellent cosmetic condition even if the packaging has seen better days. Besides some fingerprints from inspection there is one tiny ding which I circled but it honestly isn't noticeable. If you don't like the chrome it's easy to remove that panel for a sleek black look.
Viper Audio was a short-lived product line so you probably won't come across this amp again, especially unused. They're a division of DEI and the 1100.5 is almost identical to their Directed Audio 1200/5 model besides it having a variable bass EQ boost from 0 to 12db rather than a single 8db boost on the Directed.
Their amps were built very solid, running cool and usually under-rated. This was made soon after the acquisition of PPI, a/d/s and Orion so they had a ton of high quality U.S. designed internals to use in their products. The 1100.5 has enough power and crossovers to run an entire system which makes for a simpler and cleaner install.
$175 shipped
The Following User Says Thank You to Catalyx For This Useful Post:
nismos14 (01-21-2013)
Old 01-21-2013, 10:19 AM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Trades? I have a pair of beats by dre detox and I'll add $50? Or a xbox 360 bundle and I'll add $50
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 01-21-2013, 04:13 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Ship first?
Old 01-21-2013, 06:13 PM
0/11 sssssss92
Sorry, I need cash right now so the only trades I would do are for a Soundstream TN4.900D or black Focal Solid 4 amp.
Old 01-21-2013, 06:14 PM
0/11 sssssss92
Originally Posted by oslouie View Post
Ship first?
Do you mean ship without payment? The answer would be no.
Old 01-21-2013, 07:06 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Damn nice amp for the price! Trade for a DD C4b 4 channel? Small footprint
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 01-21-2013, 07:16 PM
0/11 sssssss92
That's a nice amp but actually a bit too long for under my GTI's seat. I did a ton of research to find ones that fit and are models I would buy which resulted in a very small list with the Focal Solid 4 at the top.
Old 01-21-2013, 07:19 PM
Raptor660's Avatar
0/11 sssss5243
Really? Ill be damned.. the C4b is almost micro..
2005 Buick LaCrosse
Old 01-21-2013, 07:39 PM
0/11 sssssss92
Tell me about it, there are a lot of amps I wish I could use that just barely don't fit.
The driver's seat has at most 12" but that leaves no room for plugs so it has to be a model with them on the sides if over 10.5" long. The passenger's seat has a max of 11" so I'm leaving that for a DSP eventually.
Installing anything up front is for quite a while in the future since I already have the rather amazing Dynaudio amp made for VW. It has 10 active channels, DSP pre-configured for the car, 110W x 4 RMS for woofers, 40W x 2 RMS for midrange and 25W x 4 RMS for tweeters.
It's class D but I'm still astounded they fit all that in an 11" long case...
Old 01-21-2013, 08:21 PM
Contributor
0/11 ssssss527
Gut shots?
Tags
a/d/s, directed, orion, ppi
Directed Audio D2205 5 channel Amp!!! andrewtexas123 Multi-channel Amplifiers 6 07-17-2012 03:16 PM
Rare old school Cerwin Vega 3204 4 channel amplifier Wingman0121 Multi-channel Amplifiers 27 01-29-2012 07:06 PM
Rare Phoenix Gold Roadster 66 5 channel amplifier! Shinju Multi-channel Amplifiers 10 09-17-2011 05:26 PM
Polk Audio 1100.5 All in One 5 Channel fade2AQ Multi-channel Amplifiers 1 02-28-2011 11:45 PM
directed viper 400.2 Mat J 2-Channel Amplifiers 3 04-09-2009 07:51 PM
