crescendo 1000c4 - Car Audio Classifieds!
Old 02-09-2013, 10:30 PM
bnasty's Avatar
0/11 sssssss79
Default crescendo 1000c4
crescendo 1000c4
4/3/2 Channel Class-AB Bridgeable Amplifier
Optimized PWM Power Supply
Fully stable into 2 ohms stereo and 4 ohms bridged
18db/Octave Variable Crossover Slope High Pass Filter with HPF/FULL/LPF Selection (1 for each stereo channel pair) (50hz to 1khz)
Low Pass Filter with HPF/FULL/LPF Selection (1 for each stereo channel pair) (30hz to 250hz)
Full Comprehensive Multi-way protection Circuitry with Status Light Indicators
Ultra Wide Frequency response: (10hz to 40khz)
Signal to Noise Ratio: >90dB A-Wieghted
Total harmonic Distortion: .05% at 4ohms
Operating Voltage: 9.5V to 16volts
Wired Remote Gain Controller, Blue status light
Rated Power Output(RMS)
Clean RMS power on 13.8v standard electrical system:
Rated RMS Power:
125w x4 channels at 4 ohms
250w x4 channels at 2 ohms
500w x2 bridged at 4 ohms
250w x2 bridged at 8 ohms
Specifications:
Dimensions (mm)247(W) x 61(H) x 429(L) Dimensions (in)9.7(W) x 2.4(H) x 16.9(L)
10/10 performance
7/10 condition
has wear spot on a corner where it was rubbing on something and one of the speaker terminal screws is stripped.
140 shipped
Pioneer 4400bh
2 sets of ID comps up front..Nendo 1000c4
Dc xl m1 18s.. Nendo 3k at 1 ohm
13 cube net box at 28hz
dc power spx 300 Xs 3400 front and 3100 back
Old 02-09-2013, 10:51 PM
ispector's Avatar
0/11 ssssss376
Is the head of the screw stripped or the threads on the screw or terminal block?
Old 02-09-2013, 11:18 PM
bnasty's Avatar
0/11 sssssss79
Sorry spaced out an didn't add that in there.. The terminal block itself will need to be retapped and step up to the next size screw
Pioneer 4400bh
Old 02-09-2013, 11:19 PM
bnasty's Avatar
0/11 sssssss79
I just didn't use that channel as I didn't need it..
Pioneer 4400bh
Old 02-10-2013, 08:31 PM
sub woofin's Avatar
0/11 ssssss363
is the remote included?
Old 02-10-2013, 10:10 PM
bnasty's Avatar
0/11 sssssss79
Nope.. Only comes with original box..
Pioneer 4400bh
Old 02-11-2013, 08:01 AM
hotzie's Avatar
changin the game up
0/11 ssssss793
interested in this
Old 02-11-2013, 02:54 PM
0/11 sssss1250
Feedback Score: 34 reviews
does this have bandpass capabilities?
SPL-Lab REP
Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and more support? PM me.
Old 02-11-2013, 03:03 PM
LoudnProud's Avatar
0/11 ssssss992
The c10004 does not.
Old 02-11-2013, 03:06 PM
Austin175's Avatar
0/11 sssss4224
pmed you
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Crescendo 1000c4 Like New my_stealth21 Multi-channel Amplifiers 8 10-11-2012 01:53 PM
Crescendo 1000c4 skartisu Multi-channel Amplifiers 10 07-23-2012 05:06 PM
Crescendo 1000c4 Must go! loudernu Multi-channel Amplifiers 6 04-18-2012 09:24 PM
Crescendo 1000c4 oslouie Wanting to Buy (WTB) 3 09-11-2011 04:01 PM
Crescendo 1000c4 djm4rshm2llow Multi-channel Amplifiers 12 05-09-2011 07:49 PM
