Precision Power P900.4 145W x 4 - Car Audio Classifieds!
Old 03-05-2013, 02:58 PM
0/11 ssssss627
Default Precision Power P900.4 145W x 4
6 available
Power Ratings:
RMS Power 4 Ohms(14.4V) 145W x 4
RMS Power 2 Ohms(14.4V) 225W x 4
RMS Power 4 Ohms Bridged(14.4V) 450W x 2
RMS Power 4 Ohms(12.0V) 100W x 4
RMS Power 2 Ohms(12.0V) 150W x 4
RMS Power 4 Ohms Bridged(12.0V) 300W x 2
NIB
This is my best selling amplifier, by far! Zero issues, lots of great, clear sound from a small and efficient amp. For those looking for a budget 4-channel amplifier, or even those looking to spend $300-400, zero in on this baby. You won't be disappointed.
Additional Technical Specifications:
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
102 dB Signal-to-Noise Ratio
114 Damping Factor
32 dB Stereo Channel Separation
200 mV – 6V Input Sensitivity
Input Impedance 3.3k Ohm
20-4kHz 12 dB High Pass Crossover
50-5kHz 12 dB Low Pass Crossover
Source Input Selector
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable
Band-Pass Crossovers
Direct Wire 8ga. Power & Speaker Terminals
0ga Reducer Terminal Included
Dimensions:
6.5″ W x 10.6″ L x 2″ H
Need a wiring kit? RCAs? Head unit? Dash kit? Speakers? I can get all types of product for your installation needs.
www.513electronics.com
189.99 shipping is not included
Shipped either UPS Ground with insurance and Delivery Confirmation or USPS Priority Mail
plus actual shipping charges after receiving your ZIP code
Last edited by trumpet; 03-21-2013 at 04:11 PM. Reason: check the price, shipping is not included x 2
Old 03-05-2013, 05:25 PM
Matt3824's Avatar
0/11 sssss3754
PM'd.
Old 03-05-2013, 10:11 PM
0/11 ssssss627
2 sold, 4 available
Old 03-05-2013, 10:31 PM
crownvic97's Avatar
Live. Life. Loud
0/11 sssss3620
Feedback Score: 35 reviews
Any deal on 2?
Old 03-08-2013, 09:34 AM
0/11 sssss4519
Any deal on this and a PPI BK120.2?
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 03-08-2013, 09:40 AM
0/11 ssssss627
I'm checking on this. I don't have the BK120.2 at my store but my distributor may be able to send you both amps, which will get the best price.
Old 03-09-2013, 04:22 PM
0/11 ssssss627
3 left
Old 03-11-2013, 03:17 PM
ggk ggk is offline
0/11 ssssssss8
Can these be used to run active without a processor?
Old 03-11-2013, 03:27 PM
newarkbeast973's Avatar
1/11 sssss7810
yes...
New build coming soon!!
Old 03-11-2013, 08:19 PM
0/11 ssssss627
It's a good start if you have no other way to get the bandpass filters needed when you remove passive crossovers. So yes, it can run active without a processor.
Tags
p900.4
Precision Power P900.4 145W x 4 trumpet Multi-channel Amplifiers 20 02-27-2013 09:14 AM
Precision Power P900.4 145W x 4, 4 available trumpet Multi-channel Amplifiers 17 01-26-2013 04:45 PM
used PPI P900.4 small 4-channel with big power trumpet Multi-channel Amplifiers 2 12-10-2012 02:53 PM
Precision Power P900.4 145W x 4, 8 available trumpet Multi-channel Amplifiers 9 11-30-2012 10:21 AM
