Kicker kx600.4, kx650.4 - Car Audio Classifieds!
Old 03-11-2013, 10:19 AM
0/11 ssssss229
Default Kicker kx600.4, kx650.4
Kicker kx600.4
Kicker kx650.4
kx600.4 :
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
75 watts RMS x 4 at 4 ohms
150 watts x 4 at 2 ohms
300 watts x 2 in bridged mode
speaker- and preamp-level inputs
front and rear high-pass/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
front/rear bass boost (0-18 dB at 40 Hz)
remote gain control with 25-foot cable
frequency response 20-20,000 Hz
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
unregulated Class A/B power supply offers increase in power at 2 ohms
22-9/16"W x 2-5/8"H x 10-1/4"D
kx650.4 :
4-channel car amplifier
120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
cooling fan
CEA-2006 compliant
variable front and rear high-/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
variable bass boost (0-18 dB) centered at 40 Hz with wired remote control
three-way protection circuitry
requires 4-gauge power and ground leads and an 80-amp fuse — wiring and hardware not included with amplifier
22-1/2"W x 2-9/16"H x 9-15/16"D
kx600.4 7/10
kx650.4 9/10
kx600.4 $165shipped
kx650.4 $185shipped
Old 04-19-2013, 11:00 PM
Prohibited Sellers/Buyers
0/11 sssss1590
Trades?
Kicker KX650.4 813thumper Craigslist Deals 0 01-11-2012 12:48 PM
2 kicker kx650.4 amps with end caps, fresh.. ( open to all trades ) kickerfanatic Car Audio Trader (WTT) 22 06-12-2011 09:10 AM
Kicker KX600.1 extreme Mono Amplifiers 19 09-25-2010 09:13 AM
[SOLD] BROKEN Kicker KX600.1 extremechevyman67 Broken & Non-working equipment 8 08-23-2010 11:38 PM
[SOLD] - Kicker KX650.4 MattESSC Multi-channel Amplifiers 21 07-04-2010 01:59 AM
