BNIB Fusion PowerPlant FP-1404 4-channel Amp - Car Audio Classifieds!
Old 08-06-2009, 01:32 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Feedback Score: 21 reviews
Default Relisted
1. Product: Fusion PowerPlant FP-1404 4-channel Amp
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
95 WRMS X 4 @ 4 Ohms and ≤ 1% THD+N
150 WRMS X 4 @ 2 Ohms and ≤ 1% THD+N
300 WRMS X 2
14.4 Volt Power Output Specifications
130 WRMS
210 WRMS X 4 @ 2 Ohms and ≤ 1% THD+N
425 WRMS X 2 @ 4 Ohms and ≤ 1% THD+N
Bandwidth 10Hz 40kHz
Signal to Noise >95dB
Fuse Rating 3 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz 160Hz @ 12 dB / octave
HP Variable Crossover 40 Hz 600Hz @ 12 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Subsonic Filter 20 Hz 55Hz @ 18dB / octave
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.05%
Dimensions D 2.26" (57.5mm) L 18.11" (460mm) H 8.66" (220mm)
2 Ohm Stable
MOSFET Amplifier Design
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated 8 Gauge Dual Speaker Output Connections
Gold Plated RCA Audio Input
Gold Plated RCA Audio Output for Multi-Amp installations
Amp is brand new in the original box with all OEM accessories: manual, mounting hardware and Fusion sticker.
4. Price:
Push the Envelope...Watch it Bend
Old 08-07-2009, 04:38 PM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
BUMP it!
Old 08-10-2009, 12:50 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
-EDIT-
Old 08-11-2009, 01:35 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Will consider any reasonable offer...
Old 08-12-2009, 02:33 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Wednesday bump
Old 08-14-2009, 09:00 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Pay Day Bump
Old 08-15-2009, 09:04 PM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Saturday Bump
Old 08-15-2009, 10:52 PM
0/11 ssssss237
How much for all 3 amps and connectors?
Old 08-18-2009, 01:20 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
-EDIT-
Old 08-19-2009, 02:19 PM
0/11 sssssss63
for all 3? if so pm me a shipped price to 12033
BNIB Fusion PowerPlant FP-600D (x2) toolguy420 Mono Amplifiers 30 10-07-2009 09:11 AM
F/S: BNIB Fusion 2000.1 Bigpimpin91 Mono Amplifiers 23 09-27-2009 04:18 AM
Fusion Powerplant 15" HD subwoofer mads10bass General Car Audio Discussion & Questions 0 07-10-2009 12:34 PM
Fusion Powerplant 6.5 Comps worstenemy453 Car Audio Product Reviews 0 07-07-2009 11:20 AM
BNIB Fusion Powerplant 6.5 coaxials SPL Guru Component & Coaxial Speakers 8 11-03-2008 12:49 PM
