[SOLD] NIB JL Audio 500/5 in rare all black finish from factory. - Car Audio Classifieds!
Old 08-09-2009, 09:58 PM
SPANKYSPL's Avatar
0/11 ssssss243
Default [SOLD] NIB JL Audio 500/5 in rare all black finish from factory.
Black JL Audio 500/5 power amplifier
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H (500 mm x 235 mm x 60 mm)
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
New in box, it has never been powered, never mounted, etc.
As you can expect the amp is in PERFECT condition. Comes in original packaging, with owners manual.
$600.00 plus shipping, more than $500.00 BELOW retail.
Was $600, then $500....Let's try for $400.00 plus shipping.......
Old 08-10-2009, 02:34 PM
SPANKYSPL's Avatar
0/11 ssssss243
Thank you.
Old 08-17-2009, 02:51 PM
SPANKYSPL's Avatar
0/11 ssssss243
TTT
Old 08-22-2009, 05:43 PM
SPANKYSPL's Avatar
0/11 ssssss243
TTT
Old 08-25-2009, 05:23 PM
SPANKYSPL's Avatar
0/11 ssssss243
TTT
Old 08-27-2009, 05:05 PM
SPANKYSPL's Avatar
0/11 ssssss243
Old 09-02-2009, 05:16 PM
SPANKYSPL's Avatar
0/11 ssssss243
TTT
Old 09-08-2009, 10:10 AM
SPANKYSPL's Avatar
0/11 ssssss243
TTT
Old 09-09-2009, 10:45 AM
SPANKYSPL's Avatar
0/11 ssssss243
Thank you
Old 09-20-2009, 09:01 PM
SPANKYSPL's Avatar
0/11 ssssss243
Thanks
[SOLD]Rare High End Soundstream VGA800.2 twentyfourseven 2-Channel Amplifiers 0 11-07-2009 04:44 PM
FS: VERY RARE Orion BLACK HCCA 225R PGMAN 2-Channel Amplifiers 6 07-17-2009 12:55 PM
Black Market Audio SundownAudioNY General Car Audio Discussion & Questions 19 05-14-2009 07:03 PM
[SOLD] Rare AVI LXD-160 midbass pr NIB with grills orangelss Component & Coaxial Speakers 2 03-25-2009 11:24 AM
[SOLD] Factory OEM 6 Disc CD changer/radio for Ford Lincoln Mercury Slam Head Units, Processors & EQs 0 11-25-2008 04:57 PM
