[TRADED]Brand X 4 channel - Car Audio Classifieds!
Old 09-13-2009, 06:15 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Default [TRADED]Brand X 4 channel
Brand X 4 Channel
Four channel 740-watt Mosfet amplifier
Four channel, 105 watts at 4 ohm
Four channel, 185watts at 2 ohm
Two channel, 370watts idged at 4 ohm
Hi pass crossover 40 Hz-4 kHz at 12 db (channel 1,2,3,4)
Low pass crossover 40-400 Hz at 12 db
Subsonic filter 27 Hz
Variable bass boost at 45 Hz, 18 db
Discrete class ab Mosfet mobile audio amplifier
Top-mounted fully-adjustable Linkwitz Riley crossover network
Full range pass thru line outputs
0/4 gauge billet style machined high current power and speaker terminal block
Wired bass remote control
Heavy-duty power aluminum heat sink
Power and protection led indicators
Soft turn-on/turn-off
Two 20-amp maxi fuses
Brand X 4 channel. Comes with manual and remote bass knob. A few cosmetic flaws which are pictured. They are just scratches. Works pretty good actually. Defiantly not an audison but its better than a lot of things. This was a temp amp for my E8's when i broke my SAE-1200d. Also one screw is missing on a plastic beauty piece that covers the gain setting knobs
Im thinking $80 + shipping is pretty good. might be able to get it in a flat rate. If you buy you can have those splitters.
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
Old 09-16-2009, 04:19 PM
Veteran Member
0/11 sssss4401
This is defiantly a questionable brand but is well worth what im asking. Its not worth what i paid. But its worth $85.
Sub: ---
Speaks: ---
Headunit: ---
Old 09-17-2009, 06:54 PM
Veteran Member
0/11 sssss4401
$70 + shipping = )
Sub: ---
Speaks: ---
Headunit: ---
Old 09-17-2009, 06:58 PM
orangelss's Avatar
I Role Old School
0/11 sssss2112
naughty pics with the top off?
My Allis has a big ass!!
Old 09-17-2009, 07:04 PM
Veteran Member
0/11 sssss4401
I took some, lemme find them. It doesnt look that beefy. Honestly it looks like nut sack inside. But ill try to figure out how to bench it if someone wants me too.
Sub: ---
Speaks: ---
Headunit: ---
Old 09-17-2009, 07:09 PM
Veteran Member
0/11 sssss4401
I cant find them = (
Sub: ---
Speaks: ---
Headunit: ---
Old 09-17-2009, 07:14 PM
orangelss's Avatar
I Role Old School
0/11 sssss2112
the blocks and RCA's look well made!! Well I'll quite tacking over your thread. Good luck
Old 09-17-2009, 07:17 PM
Veteran Member
0/11 sssss4401
I believe its Hifonics made. Well Hifonics styled atleast.
Sub: ---
Speaks: ---
Headunit: ---
Old 09-17-2009, 07:24 PM
Veteran Member
0/11 sssss4401
Sub: ---
Speaks: ---
Headunit: ---
Old 09-17-2009, 07:25 PM
Veteran Member
0/11 sssss4401
lol i dont know what 4 channels are supposed to look like. Maybe im not used to non beefyness.
Sub: ---
Speaks: ---
Headunit: ---
MB Quart PAB5400 5 Channel Amplifier BRAND NEW detroitbass Multi-channel Amplifiers 2 09-24-2009 04:53 PM
WTB 4 channel amp madmat Wanting to Buy (WTB) 6 07-18-2009 12:49 PM
WTB: 4 Channel Amp 528hz Wanting to Buy (WTB) 8 01-16-2009 08:11 PM
do you like my 4 channel amp?!?! bangin hoe Member Rides & System Pictures 14 08-29-2008 07:37 AM
