2 new b2 audio quattro - Car Audio Classifieds!
Old 05-25-2015, 10:04 AM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default 2 new b2 audio quattro
1. Product: b2 audio 4 channel
ACTIVE EVOLUTION
With evolution things change & adaptation is the norm.
The new Quattro shows that a compact footprint is not equal to less muscle.
Instead of switching to class D full range, we chose the evolution, class H. This enables us to make an efficient amplifier with the qualities of a class A/B, but where the power output is superior even with smaller footprints.
So the Quattro has shed some weight and is even sleeker than before. But even though the width is more than 2" less than prior, we were able to increase performance with 10%.
Also the appearance has been brushed up, now the RCA inputs are upgraded to mini Tiffany, which enables better and more secure connections.
For the audio purists that want to keep things simple, there is an added feature. The amplifier will change its circuit from a 4 ch to a hybrid 4 ch active. That way you can have your tweeters on one pair of channels, the mid ranges on the other. Might not sound new? Well you will only need to run 1 set of RCA inputs to the amp and you only need to use 1 gain and 1 setting for the crossover, since the high pass setting is also determining the low pass crossover settings.
But fear not, it can still be used as an ordinary 4 ch with full range on all or low pass with bass remote on channel 3/4.
Welcome to the Active Evolution of the Quattro.
PRODUCTS SHIP FROM EUROPE. CUSTOMER IS RESPONSIBLE FOR ANY IMPORT TAXES AND DUTIES!
Frequency Response: 9 Hz ~ 42 KHz
Signal to Noise Ratio: > 95 dB
Input Sensitivity: 4 ~ 0.2 V
Crossover: 12 dB / Oct
High Pass Filter (ch 1 & 2): 50 Hz ~ 250 Hz
High Pass Active - TLA (ch 1 & 2): 1 KHz ~ 5 KHz
Tonal Level Adjustment (TLA): -12 dB ~ 0 dB from HPF point
High Pass Filter (ch 3 & 4): 50 Hz ~ 250 Hz
Low Pass Filter (ch 3 & 4): 50 Hz ~ 250 Hz
Bass Boost @ 45 Hz: 0 ~ 15 dB
Remote Control: Optional
Damping Factor: >800
Fuse Rating: 75 A
Operational voltage: 10 V ~ 15.5 V
Dimensions: 178 x 51 x 340 mm / 7" x 2" x 13.38"
14.4V 14.4V Bridged* Drop 14.4V Bridge*
Power @ 4 : 4 x 100 w 2 x 300 w 2 x 350 w
Power @ 2 : 4 x 150 w
new never used , still factory wrapped in plastic only opened box for pics.only reason i'm selling is working 14 hrs a day 6 days per week and don't have time for audio .
325 per amp shipped in the con u.s.
not looking for trades but can work out payments
Old 05-25-2015, 02:28 PM
0/11 sssss3232
Feedback Score: 17 reviews
pm me best price on both
TEAM420
TEAM XSPOWER
TEAM DC AUDIO
SS 1-2 3rd PLACE 2007 INDY "REGIONALS"
SS 1-2 1ST PLACE INDY AND 2008 NATIONAL CHAMPION.
Old 05-25-2015, 03:06 PM
caloriu's Avatar
0/11 sssss2863
both amps sold to loudmofo
0/11 sssss3232
thank you sir.
TEAM420
TEAM XSPOWER
TEAM DC AUDIO
Minty B2 Audio Quattro 10F jfoodstamp Multi-channel Amplifiers 3 10-15-2014 08:46 PM
[SOLD] B2 audio quattro korey_hofer Multi-channel Amplifiers 4 07-20-2013 02:47 PM
BNIB B2 Audio Quattro 4 channel Jayzbent Multi-channel Amplifiers 4 06-21-2013 04:15 PM
B2 audio quattro korey_hofer Multi-channel Amplifiers 2 05-17-2013 03:19 PM
WTB B2 Audio Quattro Jayzbent Wanting to Buy (WTB) 1 01-05-2013 06:34 PM
