Sundown sax-125.4 16volt stable - Car Audio Classifieds!
Old 08-04-2015, 09:43 AM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
Default Sundown sax-125.4 16volt stable
Sundown Audio sax-125.4
Two available. These will do 150w x4 on 12v. 16v stable for anyone running a higher voltage setup.
The SAX-125.4 is built to the same exacting standards as the SAX-100.4D. It's flexible crossovers allow the user to run a 2-way active speaker setup with no external processing. It packs enough punch that one could also run a set of front speakers with one pair of channels and a subwoofer, bridged, on the other pair of channels for use as a total system amplifier where high power is not required.
FEATURES & SPECIFICATIONS: RATED POWER OUTPUT:
Full range digital 4channel amplifier
High efficiency 4channel
Stable into 2 ohm stereo or 4 ohm mono
12 dB/oct, variable subsonic filter
12 dB/oct, variable high pass filter
12 dB/oct, variable low pass filter
x1, x10 crossover multiply
4 ways protection circuit
(thermal, voltage, speaker short and DC)
Wired remote control included
RMS power, 4 ohm stereo 125W x 4CH
RMS power, 2 ohm stereo 200W x 4CH
RMS power, 4 ohm bridged 400W x 2CH
Signal / Noise Ratio 105dB
Subsonic frequency crossover 10Hz ~ 500Hz
High pass frequency crossover 50(500)Hz ~ 500(5K)Hz
High pass frequency multiply x1, x10
Low pass frequency crossover 50(500)Hz ~ 500(5K)Hz
Low pass frequency multiply x1, x10
Frequency response 20Hz ~ 20KHz ( +/- 3dB )
Input sensitivity 6V ~ 0.2V ( +/- 5% )
T.H.D @ 4ohm < 0.1%
Efficiency @ 4ohm 70%
Fuse Rating 30A x 2
Dimensions 8.25"(W) x 2.32"(H) x 11.02"(L)
Used with cosmetic scratches. Perfect working condition.
$300 shipped. Two available.
Old 08-05-2015, 12:13 PM
Derrick824's Avatar
0/11 sssss2362
One sold.
Still have one left.
Old 08-07-2015, 10:27 AM
0/11 sssssss54
I'm a pointy head SQ guy. I probably couldn't hear the difference in any A/B comparison of amps. I've seen many Sundown products sold here. Just wondering why people buy and sell them so often. I keep looking at this amp and thinking, I need this one. Convince me why I need this as much as I think I do...
Old 08-07-2015, 11:54 AM
0/11 ssssss822
^^^small footprint & big power. i have one myself
01 tahoe 80prs
275 & 350 singer alt
2 black cherries
levi iii
2 12's dds tridents
4 cf 8's & vifas xt25's
Sundown SAX-125.4 Hixystick Multi-channel Amplifiers 0 11-02-2013 03:59 PM
Sundown SAX-125.2 impryder Wanting to Buy (WTB) 2 11-05-2012 08:26 PM
FS: Sundown SAX 125.2 __d_a_v_i_d__ 2-Channel Amplifiers 15 06-30-2012 05:31 PM
Sundown SAX 125.2 chance174 Wanting to Buy (WTB) 0 05-28-2012 12:07 PM
FS: Sundown SAX 125.2 $LICK CALIFA$ 2-Channel Amplifiers 13 11-28-2011 02:49 PM
