[SOLD] Sundown 50.4 - Car Audio Classifieds!
Old 10-20-2009, 11:55 AM
Prohibited Sellers/Buyers
0/11 sssss2890
Arrow [SOLD] Sundown 50.4
Sundown 50.4
The SAX-50.4 was designed as a "little brother" to the SAX-100.4 for those that do not need as much power and/or have limited space to work with. The SAX-50.4 matches very well with the SAZ-1000D as a complete amplification system.
The same crossover features as the SAX-100.4 "C" revision are included.
SPECIFICATIONS:
  • 4/3/2 Channel Bridgeable Class-AB Amplifier
  • MOSFET PWM Power Supply
  • Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
  • 12dB Octave Electronic Crossover Slope
  • Variable Subsonic Filter
  • Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
  • Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
  • Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
  • Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
  • Independent 1/2 and 3/4 Channel Bass Boost Variable Control
  • Variable Bass-Boost Frequency Control
  • Variable Input Level Control
  • Input Sensitivity : 200mV ~ 6V
  • Subsonic Filter : 10Hz ~ 500Hz
  • Signal Input and Line Out RCA Connectors
  • Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
  • Tested Voltage & THD: 14.4V & Less than 0.05% THD
  • Operating Voltage : DC10V~16V Power Input
  • Wired Remote Controller
  • MSRP $349 USD
Rated power output ----RMS power, 4 ohm stereo
50W x 4CH ----RMS power, 2 ohm stereo
80W x 4CH ----RMS power, 4 ohm bridged
160W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4) High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4) Variable Subsonic Filter 10Hz to 500Hz Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) [email protected] Watts <0.1% Channel Separation 75dB Fuse Rating 25A x 2 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 310(L)mm
Used in very good condition sounds great have org box as well.
$180 shipped
Old 10-20-2009, 12:22 PM
snoopysnooper's Avatar
Awaiting Confirmation
0/11 sssss4665
Feedback Score: 33 reviews
you wouldnt want to trade a diamond 800.1+ 50 bucks would you?
2006 grand caravan
sony dsx-s210x
lanzar opti 2k
3 sundown sa8v2d4
t-line unloading at 34
juice box black cherry
Old 10-20-2009, 12:23 PM
0/11 sssss2890
NO TRADES SORRY... I forgot to add that..
Old 10-23-2009, 11:59 PM
0/11 sssss2890
yum yum..
Old 10-24-2009, 09:52 AM
0/11 sssssss31
what voltage is is 50watts at 14.4?
Old 10-24-2009, 10:29 AM
0/11 sssss2890
not sure if the testing is done at 14.4 or 12 to be honest, I know it was loud on my system never had an issue
Tags
50.4, audio, sundown
[SOLD] Sundown SAX-100.4d SPY Multi-channel Amplifiers 6 09-22-2009 10:40 AM
[SOLD] Sundown 50.4 orangelss Multi-channel Amplifiers 23 08-26-2009 06:59 PM
[SOLD!]Sundown SAE 1200D[SOLD!] KeepinItSimple Mono Amplifiers 9 06-07-2009 03:30 PM
[SOLD] FS Sundown SAZ 1500D $300 with 17 feet of 0ga free with purchase SOLD SoundWerx Mono Amplifiers 8 01-08-2009 05:17 PM
[SOLD] ED 12s & sundown e8 RidnClean Car Audio Packages 6 11-09-2008 06:03 PM
