Audison Voce AV5.1K - Car Audio Classifieds!
Old 11-26-2015, 04:39 PM
0/11 ssssss282
Default Audison Voce AV5.1K
Audison Voce AV5.1K
POWER SUPPLY
  • Power supply voltage: 11 15 VDC
  • Idling current: 3 A
  • Idling current when off: 0.02 mA
  • Consumption @ 14.4 VDC (Max Musical Power): 110 A
AMPLIFIER STAGE
  • Distortion - THD (1k Hz @ 4Ω ) A, B Ch: 0.05 %
  • Distortion - THD (100 Hz @ 4Ω), C (sub) Ch: 0.3 %
  • Bandwidth (-3 dB) A, B Ch: 4 60k Hz
  • Bandwidth (-3 dB) C (sub) Ch: 7 350 Hz
  • S/N ratio (A weighted @ 1V) A, B Ch: 100 dB
  • S/N ratio (A weighted @ 1V) C (sub) Ch: 87 dB
  • Damping factor (1k Hz @ 4Ω) A, B Ch: 100
  • Damping factor (100 Hz @ 4Ω) C (sub) Ch: 80
  • Input sensitivity: 0.3 5 V RMS
  • Input impedance: 15k Ω
  • Speaker-In sensitivity: 1.4 24 V RMS
  • Speaker-In impedance: 5k Ω
  • Minimum load impedance A / B / C Ch: 4Ω / 2Ω / 2Ω
  • NOMINAL POWER (RMS) A + B + C Ch @ 12 VDC,
  • THD 0,3%, 4Ω: 50 W x 2 + 120 W x 2 + 500 W x 1
  • OUTPUT POWER (RMS) A + B + C Ch @ 14.4 VDC, THD 1%:
  • 5 Ch: 75 W x 2 (4Ω) + 140 W x 2 (4Ω) + 600 W x 1 (4Ω)
  • 5 Ch: 75 W x 2 (4Ω) + 140 W x 2 (4Ω) + 1000 W x 1 (2Ω)
  • 5 Ch: 75 W x 2 (4Ω) + 250 W x 2 (2Ω) + 1000 W x 1 (2Ω)
SIGNALS INPUTS / FILTERS
  • Inputs: Pre IN / Speakers IN
  • Outputs: Pre OUT Full Range
  • A Ch Filters (Full / Hi-Pass):
  • 50 5k Hz (2 range) @ 12 dB/Oct.
  • B Ch Filters (Full / Hi-Pass / Band-Pass):
  • 50 1k Hz (Hi) / 250 5k (Lo) @ 12 dB/Oct.
  • C Ch Filters (Full / Lo-Pass): 50 150 Hz @ 24 dB/Oct.
OTHER FUNCTIONS
  • Remote IN: 7 15 VDC - 1mA
  • Remote OUT: 12 VDC - 50mA
  • Fuse (Strip type): 100 A
  • Remote SUB volume adj.: (-50 6) dB
  • Speakers IN Turn-on (ART): Selectable
DIMENSIONS:
  • Max size (mm/inches): 220 x 470 x 58 / 8,66 x 18,50 x 2,28
I used this amp to power my Seas components and 2 Alpine SWR-T10. Also had an Audison Bit Ten hooked up. Has a scratch shown in the picture on the underside, other than that the amp is in perfect condition and working condition. Have original box but no manual. Which can be easily downloaded.
$1150 Shipped
2005 Laser Blue Impala SS
HU: Eclipse CD8443, Front: Seas Lotus Performance, Subs: Eclipse SW8122.4, Amps: Audison Voce AV 5.1K, Processor: Audison Bit Ten
Old 11-30-2015, 03:01 PM
0/11 ssssss282
Bump...
I will accept best /reasonable offers. This is a great amp ladies and gentlemen!
Old 12-15-2015, 04:50 PM
0/11 ssssss282
lookin for some love
Old 12-27-2015, 03:00 PM
0/11 ssssss282
$1000 shipped
Old 01-12-2016, 06:01 PM
0/11 ssssss282
sold .
Audison Voce Components alex.j.perez Component & Coaxial Speakers 7 06-17-2013 08:00 PM
