OS Mtx 4244 4ch Amp - Car Audio Classifieds!
Old 01-07-2016, 11:12 PM
rdooski3's Avatar
0/11 ssssss625
Default OS Mtx 4244 4ch Amp
OS Mtx 4244
Very underrated at
45x4 @ 4ohms
65x4 @ 2ohms
But it has 50 amps of fusing so its actually more like
80x4 @ 4ohms
125x4 @ 2ohms
Nice underrated old school workhorse. Its in decent condition and everything functions as it should. I've always loved these old mtx amps and anyone who has owned one would surely tell you the same. The only thing missing is a few of the speaker output screws.
he MTX Thunder4244 4-channel amplifier uses a "pure N-channel" design with a MOSFET power supply for impressive power and outstanding performance. This efficient circuitry turns most of the available energy into usable wattage, rather than the heat generated by most amps.
Intelligent Surface Mount Technology gives the amplifier superior resistance to vibration, for long-term reliability. Speaker-level inputs feature SmartEngage, which turns the amp on when it gets signal from the receiver.
Details:
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
60 watts x 4 at 2 ohms
120 watts x 2 in bridged mode
requires 4-gauge power and ground leads wiring and hardware not included with amplifier
PWM MOSFET switching power supply
Intelligent Surface Mount Technology for cleaner sound
front selectable 85 Hz high-pass crossover, 18 dB/octave
rear selectable 85 Hz high-pass/low-pass crossover, 18 dB/octave
preamp outputs
speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
9-5/16"W x 2-1/8"H x 11-1/2"D
$75 shipped
andamanauctions -
"Center speaker has been cut, possibly by manufacturer and appears to be professionally repaired with black tape. This appears very professional and might be by design. The tape used is not some cheap electrical tape, but a light fabric-like tape. I assume if you are bidding on this high-end speaker, that you are an audiophile and aware of the origins of the anomaly."
Old 01-09-2016, 02:10 AM
rdooski3's Avatar
0/11 ssssss625
Sold....
andamanauctions -
Old 01-09-2016, 10:24 AM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2084
Feedback Score: 32 reviews
M i n e .
If I were gay I would marry you.
Funny how a girl stops talking to you when you say you would rather be homeless and give her nothing than have a kid...women...
OLD School MTX Thunder 4244 BNIB cerwinvega_fan Multi-channel Amplifiers 9 04-04-2016 02:36 PM
OLD School MTX 4244 Timhof13 Multi-channel Amplifiers 23 02-21-2015 10:06 PM
2 12" mtx RS4412 subwoofers subs with mtx tc2002 amp amplifier thel.t.d.supply Car Audio Packages 1 01-07-2011 06:12 PM
mtx te400d1 and mtx amp for highs! deepsilencer Wanting to Buy (WTB) 0 01-03-2011 01:30 PM
Components & 4ch Amp - possibly kick panels for jimmy/blazer extreme Wanting to Buy (WTB) 5 12-27-2010 05:41 PM
