Elemental Designs nine.4 - Car Audio Classifieds!
Old 01-18-2016, 09:35 PM
0/11 sssssss70
Default Elemental Designs nine.4
NINe.4
65W x 4 @ 4 Ohm
100W x 4 @ 2 Ohm
150W x 2 @ 4 Ohm
Height : 2.250"
Width : 9.850"
Length : 12.000"
Overall Length(w/ feet) : 13.100"
The amp does have a few scratches on it since it was under the seat of my truck for a few years. I recently upgraded to a smaller amp so the seat wouldn't rub against it anymore when I move it. I do want it known that this amp has cut out on me a few times. It would cut off then go right back as if nothing happened. It worked perfectly for the past month before I removed it.
$140 shipped
I'm open to offers. I'm not interested in any trades at this time.
Attached below
Old 02-24-2016, 01:53 AM
RandyJ75's Avatar
0/11 sssssss60
Any idea as to why the amp would cut out on you? Bad connection, or something internal in the amp itself?
I am interested, but worried that the amp may not work if I bought it from you.
Would you offer a warrantee? The amp will be installed by a friend of mine who is an Electrical Engineer.
Thanks
built coming
Old 02-24-2016, 11:53 AM
0/11 sssssss70
I really don't know if the issue was in the amp or otherwise. When I swapped amps, I also changed my ground from 4ga to 8ga, reinserted my inline fuse, added a new HU, and removed the LOC that I had connected to my stock HU. It worked fine for me the last month or so that it was installed before I removed it, and as such I'm selling it as-is.
Elemental Designs Nine.2x johnjv29 2-Channel Amplifiers 9 07-31-2013 11:50 AM
Elemental Designs nine.5 Team Elite Mike Multi-channel Amplifiers 19 06-03-2012 09:41 PM
Elemental Designs Nine.2x Pieper CACO Amp Internals 0 10-22-2010 07:31 PM
Elemental Designs Nine.1 alexis8284 Mono Amplifiers 27 09-22-2010 01:30 AM
Elemental Designs NINe.4? Anyone have one? AuZy_AuDiO General Car Audio Discussion & Questions 2 06-27-2010 08:51 AM
