FS: Massive NX5 - Car Audio Classifieds!
Old 02-20-2016, 12:25 AM
super_duper's Avatar
0/11 sssss1595
Default FS: Massive NX5
Massive NX5
Massive Audio NX5 Nano Block Series 5-Channel Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 120 watts x 4 chan. + 200 watts x 1 chan.
2 ohms: 240 watts x 4 chan. + 400 watts x 1 chan.
1 ohm: 800 watts x 1 chan. (Subwoofer channel only)
Bridged, 4 ohms: 480 watts x 2 chan. + 200 watts x 1 chan.
MOSFET power supply with high grade switching devices
LED power/protect indicators
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
2-Channel operation
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable high-pass filter (40-200 Hz, 24 dB/octave)
Adjustable low-pass filter (20-200 Hz, 24 dB/octave)
Frequency response: 20-25,000 Hz
THD (Total Harmonic Distortion): <0.05%
Signal-to-Noise Ratio: >89 dB
Max Voltage: 15V
Max RCA Voltage: 5V
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
CEA-2006 compliant amplifier
Also found as: Massive Audio SKUNX2
Weight: 15 lbs
Dimensions: 15"L x 5-1/2"W x 2-1/8"H
Used in excellent working condition
$235 shipped
Old 02-20-2016, 03:11 AM
Red Light Ear Rapist
0/11 sssss1397
Solid seller ,free bump
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
The Following User Says Thank You to Chris McNeeley For This Useful Post:
super_duper (02-20-2016)
making changes .. Massive Nx5 ? etznova General Car Audio Discussion & Questions 3 09-30-2013 01:16 PM
massive audio nx5 question kurupt305 General Car Audio Discussion & Questions 4 07-18-2013 02:59 PM
Wtb:massive audio nx5 rocksolid84 Wanting to Buy (WTB) 0 02-06-2013 03:11 AM
Massive Audio NX5 Boomintahoe CACO Amp Internals 0 12-18-2012 05:14 PM
FS Massive Audio NX5 jammer750 Multi-channel Amplifiers 12 01-07-2012 06:31 PM
