Zed audio draconia - Car Audio Classifieds!
Old 03-23-2016, 12:01 AM
0/11 ssssss243
Default Zed audio draconia
1. Product: ZED AUDIO DRACONIA 600/4
2. Specs: Rated power is 175 watts x 4 into 4 ohm or 250w x 4 into 2 ohm.
Bridged power is 350w x 2 into 8 ohm or 500w x 2 into 4 ohm.
The pairs of channels are independently bridgeable.
Two or four input configuration.
Channels 1+2 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
Channels 3+4 in addition feature SUB MODE which introduces a 24dB per octave variable subsonic crossovers and a 40Hz constant Q equalizer.
Level controls accommodate input levels up to 8.0v RMS.
Pre-amplifiers utilize a fully isolated power supply for zero ground loops.
Pre-amplifiers drive the main amplifiers in a fully balanced mode.
Class D amplifiers utilize high-speed high current low gate charge MOSFETs.
Fully regulated power supply delivers power independent of battery voltage.
There are a total of thirteen regulated power supplies.
The power supply utilizes six 110 amp MOSFETs in a source follower configuration for maximum bandwidth.
Low ESR 105C capacitors are used in the power supply.
Very high efficiency owing to the smart power supply.
USED GOOD CONDITION
400 PLUS SHIPPING OBO
The Following User Says Thank You to benz280se For This Useful Post:
graham (03-23-2016)
Old 03-23-2016, 06:14 AM
Loud and Proud's Avatar
Loyal Member
0/11 sssss1570
Feedback Score: 29 reviews
Any trades plus cash?
Old 03-23-2016, 01:06 PM
0/11 ssssss243
What u have in mind?
Old 03-23-2016, 08:41 PM
Loyal Member
0/11 sssss1570
Pm sent..
Zed draconia benz280se Multi-channel Amplifiers 7 06-23-2015 09:08 PM
WTB--Zed Draconia II Dester Chaos Wanting to Buy (WTB) 3 11-05-2014 04:51 PM
ZED Audio Draconia-II fastass09 Multi-channel Amplifiers 9 04-17-2014 09:10 PM
zed levithian or draconia matt14 Wanting to Buy (WTB) 1 08-13-2013 08:32 PM
WTB: Zed Draconia BudgetBass Wanting to Buy (WTB) 3 02-01-2013 12:02 PM
