Phoenix Gold Ti800.4 - Car Audio Classifieds!
Old 04-11-2016, 07:14 PM
0/11 ssssss728
Feedback Score: 42 reviews
Default Phoenix Gold Ti800.4
Dynamic Power 14.4Vdc >1% THD
125 x 4 @ 4 ohm Stereo
200 x 4 @ 2 ohm Stereo
400 x 2 @ 4 ohm Bridged
RMS Power 14.4Vdc ≤1% THD
115 x 4 @ 4 ohm Stereo
150 x 4 @ 2 ohm Stereo
300 x 2 @ 4 ohm Bridged
Frequency Response: 1dB from 20Hz to 20kHz
Signal to Noise Ratio: >110dB
High and Low Pass Crossovers: 18dB per Octave
Low Pass Crossover Range: 40Hz to 400Hz
High Pass Crossover Range: 20Hz to 400Hz
Bass Boost @ 45Hz: 0 to +18dB
Low Level Input Range: 200 millivolts to 8 volts
Lowest Recommend Load: 4 ohm Bridged or 2 ohm Stereo
Typical Efficiency: 50%
Damping Factor Greater than 200
Recommended Fuse Size: Minimum 100A
Power/Ground Wire Size: 4 Gauge
Dimensions: 20.4 L x 9.8 W x 2.5 H 518mm x 252mm x 62mm
3. Description/Condition: Great condition with a couple barely noticeable marks on it. Only the amp is included, no original packaging.
4. Price: :$275 shipped. Will do partial trade for an Ed Nine.4 but may consider a nine.2x
2 Phoenix Gold xs4600s nutxo Multi-channel Amplifiers 13 08-18-2012 02:18 PM
Phoenix Gold The One Wingman0121 CACO Amp Internals 9 05-26-2012 03:40 PM
Phoenix Gold Ti800 diatribe CACO Amp Internals 0 05-26-2012 03:24 PM
Phoenix Gold TI DD-10 nutxo Wiring, Electrical & Other Installation Equipment 2 08-02-2011 02:47 PM
Phoenix gold eq AUDIO_BASSICS Head Units, Processors & EQs 0 09-23-2009 09:31 AM
