Rockford Fosgate Punch 160.4 MINT!!! - Car Audio Classifieds!
Old 04-17-2016, 03:53 AM
0/11 ssssss153
Default Rockford Fosgate Punch 160.4 MINT!!!
Continuous Power Rating (Competition Standard) Measured at 13.8V
RMS continuous power per channel, all channels 20 Watts
driven into a 4W load from 20-20,000Hz with
less than 0.05% Total Harmonic Distortion (THD)
RMS continuous power per channel, all channels 40 Watts
driven into a 2W load from 20-20000Hz, with
less than 0.1% Total Harmonic Distortion (THD)
RMS continuous power bridged x 2 into a 4W load 80 Watts
from 20-20000Hz, with less than 0.1%
Dynamic Power Rating (IHF-202 Standard) Measured at 14.4V
2-Channel bridged into a 4W load 120 Watts
per channel into a 2W load 60 Watts
per channel into a 4W load 40 Watts
Signal-to-Noise Ratio (A-weighted) >100dB
Factory Default Crossover Point 80Hz Butterworth (.047mf)
Crossover Alignment 12dB/octave
Dimensions 95⁄8"W x 139⁄32"L x 25⁄8"H
(24.4cm) x (33.73cm) x (6.6cm)
Damping Factor @ 4W (at output connector) >150
Bandwidth 15Hz-100kHz 3dB
Frequency Response 20Hz-20kHz 0.5dB
Slew Rate 30 V/ms
IM Distortion (IHF) <0.05%
Input Sensitivity Variable from 150mV to 3V
Preset at the factory for 500mV
B+ Fuse Size (external to amplifier) 30 amp ATC
Input Impedance 20k ohms
Was in a car i purchased, owner was an older man whop said he bought this 2 years after he bought his car in 1990, this amp is in MINT condition, still even has the Warranty VOID Stickers intact.
$100 Shipped or trade for a at least 500w Mono amp.
The Following User Says Thank You to Chaoticdopey For This Useful Post:
colorblind83 (04-18-2016)
Old 04-17-2016, 09:03 AM
Super Moderators
0/11 sssss9623
proper pics please
Old 04-17-2016, 01:59 PM
0/11 ssssss153
Originally Posted by xjoeyc23x View Post
proper pics please
what do you mean proper pics?
Old 04-17-2016, 02:18 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Username and date has to be in the pic
My game is legit,
Old 04-17-2016, 03:38 PM
0/11 ssssss153
Last time i checked the rules it said if you have 5 or more itrader i didnt have to post username and date. But if its guna make a fuss ill add it when inget home
Old 04-18-2016, 05:11 PM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2079
Feedback Score: 32 reviews
500 rms?
at one ohm?
Old 04-18-2016, 11:52 PM
0/11 ssssss153
Originally Posted by colorblind83 View Post
500 rms?
at one ohm?
1 ohm preferable or maybe 600w at 2ohms
Old 08-01-2016, 08:30 PM
sgtskip's Avatar
Banannas are bad for you,
0/11 ssssss302
Default Rockford 160.4
Do you still have it for sale?
SKiP
Hate being Bi-Polar...... its Friggen Awesome
Old 08-02-2016, 02:37 AM
0/11 ssssss153
SKiP
Yes
Mint Rockford Fosgate Punch HE 10" silvercookie 10" Subwoofers 3 12-05-2012 10:00 AM
FS: 2 Mint Rockford Fosgate Punch HX2's. Dual 4. silvercookie 12" Subwoofers 3 12-05-2012 10:00 AM
Rockford Fosgate The Punch PCH-128 8 ohm Subs 12 Inch Near Mint mizatt32 eBay 2 04-26-2012 02:10 AM
rockford fosgate punch 160.4 kn0wledge000 Multi-channel Amplifiers 16 05-26-2011 11:41 PM
