[NLFS] Sundown 50.4 w/warranty - Car Audio Classifieds!
Old 12-14-2009, 11:19 AM
Prohibited Sellers/Buyers
0/11 sssss2890
Smile [NLFS] Sundown 50.4 w/warranty
Sundown 50.4
The SAX-50.4 was designed as a "little brother" to the SAX-100.4 for those that do not need as much power and/or have limited space to work with. The SAX-50.4 matches very well with the SAZ-1000D as a complete amplification system.
The same crossover features as the SAX-100.4 "C" revision are included.
SPECIFICATIONS:
  • 4/3/2 Channel Bridgeable Class-AB Amplifier
  • MOSFET PWM Power Supply
  • Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
  • 12dB Octave Electronic Crossover Slope
  • Variable Subsonic Filter
  • Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
  • Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
  • Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
  • Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
  • Independent 1/2 and 3/4 Channel Bass Boost Variable Control
  • Variable Bass-Boost Frequency Control
  • Variable Input Level Control
  • Input Sensitivity : 200mV ~ 6V
  • Subsonic Filter : 10Hz ~ 500Hz
  • Signal Input and Line Out RCA Connectors
  • Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
  • Tested Voltage & THD: 14.4V & Less than 0.05% THD
  • Operating Voltage : DC10V~16V Power Input
  • Wired Remote Controller
  • MSRP $349 USD
Rated power output ----RMS power, 4 ohm stereo
50W x 4CH ----RMS power, 2 ohm stereo
80W x 4CH ----RMS power, 4 ohm bridged
160W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4) High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4) Variable Subsonic Filter 10Hz to 500Hz Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) [email protected] Watts <0.1% Channel Separation 75dB Fuse Rating 25A x 2 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 310(L)mm
Used in very good condition sounds great have org box as well. Still under warranty.
$190 shipped
Old 12-14-2009, 05:36 PM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
How much power can you expect to get out of one of these?
Old 12-14-2009, 05:40 PM
0/11 sssss2890
Rated at 50x4 at 4 ohm about 100x4 at 2 ohm I am sure its a little under rated like most of sundowns amps.
Old 12-16-2009, 12:34 PM
0/11 sssss2890
bump
Old 12-20-2009, 09:59 AM
0/11 sssss2890
bump
Old 01-18-2010, 01:00 PM
0/11 ssssss203
willing to trade? i have a 12" kicker l7 D2 06 model, a KENWOOD KAC-9103D, and a ofna 9.5 violator 4x4 nitro buggy
Old 01-20-2010, 04:49 PM
0/11 sssss1435
Trades?
[NLFS] F/S - BNIB Sundown Audio SAZ-4500D SundownAudioNY Mono Amplifiers 4 01-14-2010 12:13 PM
[NLFS] Sundown Nightshade 12" D1 Custom RetroAudioInc 12" Subwoofers 15 11-06-2009 07:39 AM
[FOUND]WTB Sundown 1500d or 2000d w/any Warranty. AuZy_AuDiO Wanting to Buy (WTB) 7 11-04-2009 07:02 AM
[NLFS] Sundown 125.2 orangelss 2-Channel Amplifiers 5 08-26-2009 07:08 PM
