ZED Audio Leviathan - III 6 channel amplifier - Car Audio Classifieds!
Old 07-09-2017, 04:14 PM
0/11 sssssss13
Default ZED Audio Leviathan - III 6 channel amplifier
LEVIATHAN is a very unique amplifier in the multi-channel arena. Almost all other multi-channel amplifiers utilize staggered power configurations meaning that the first 4 channels inevitably have a very modest output. Zed has travelled a different route, we offer all 6 channels with the same power. We are thus able to offer a platform which is infinitely more variable than others.
Rated power is 150 watts x 6 into 4 ohm or 300w x 6 into 2 ohm.
Bridged power is 300w x 3 into 8 ohm or 600w x 3 into 4 ohm.
The 3 pairs of channels are independently bridgeable. Two, four or six input configuration.
Channels 1+2 feature a 24dB per octave Linkwitz Riley High crossover.
Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass or Low Pass from channels 5+6.
Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass or Low Pass from channels 5+6. .
Channels 5+6 feature feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 5+6 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
The High Pass crossover doubles as a subsonic filter as it is able to respond down to 10Hz.
LEVIATHAN Is well suited to running a multitude of different systems from simple 4 satellite/sub woofer type to tri and quad amped systems. Level controls accommodate input levels up to 8.6v RMS. Pre-amplifiers utilize a fully isolated power supply for zero ground loops. Pre-amplifiers drive the main amplifiers in a fully balanced mode. Class D amplifiers utilize high-speed high current low gate charge MOSFETs. Fully regulated power supply delivers power independent of battery voltage. There are a total of seventeen regulated power supplies. The power supply utilizes twelve 110 amp MOSFETs in a source follower configuration for maximum bandwidth. Low ESR 105C capacitors are used in the power supply. Very high efficiency owing to the smart power supply. Tiffany RCA's with Teflon inserts are used for ultimate quality and reliability. Made in the USA
Great condition. I also have a set of Focal Utopia 3 ways and a Mosconi 6 to 8 DSP for sale.
$500 shipped to lower 48.
The Following User Says Thank You to macming For This Useful Post:
graham (07-09-2017)
Old 07-09-2017, 05:31 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Username?, Date?
Sent from my SAMSUNG-SM-G530AZ using Tapatalk
Old 07-09-2017, 05:55 PM
0/11 sssssss13
Originally Posted by jigsizzle View Post
Username?, Date?
I'm not sure what you are looking for. I don't think I did anything different than other ads listed here.
Old 07-09-2017, 06:15 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Yea, I bet...
Put your username and today's date on a piece of paper and take a pic of it with the product you're selling sir...
The Following User Says Thank You to jigsizzle For This Useful Post:
graham (07-09-2017)
Old 07-09-2017, 07:25 PM
newarkbeast973's Avatar
0/11 sssss7810
For newer members with little or no reputation. Ppl ask for proof that you actually own the product you're selling to feel safer about purchasing
New build coming soon!!
Old 07-09-2017, 09:37 PM
0/11 sssssss13
Yea, I bet...
Updated the original post with a picture of my user name and date with the amp.
I understand the reason behind this practice, it just wasn't clear from his first post. Anyways, thanks for the tip and I just updated the first post.
Old 07-09-2017, 09:39 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Appreciate it man 👍
Old 07-11-2017, 12:37 PM
0/11 sssssss13
To the member that just messaged me regarding the Zed Audio amp, I tried to reply but your inbox is full. Let me know when I can respond.
Old 07-18-2017, 10:00 PM
0/11 sssssss13
Price drop
Pioneer P99RS, RD 7500.1, Ascendent Audio Mayhems, Zed Audio Leviathan III jockhater2 Craigslist Deals 14 11-17-2014 05:35 PM
ZED Draconia III 4 channel BNIB Eldiablos2ndman Multi-channel Amplifiers 2 08-13-2012 06:25 PM
ZED LEVIATHAN III 6 channel amplifier BNIB Eldiablos2ndman Multi-channel Amplifiers 3 08-04-2012 07:20 AM
Mint Zed Audio Leviathan 6ch amplifier AV8ter Multi-channel Amplifiers 3 08-29-2011 09:36 PM
