Audison AV 5.1K including Audison Bit In - Car Audio Classifieds!
Old 07-18-2017, 11:47 PM
SPANKYSPL's Avatar
0/11 ssssss243
Default Audison AV 5.1K including Audison Bit In
Audison Voce AV 5.1K
Audison Bit In
POWER SUPPLY
Power supply voltage: 11 15 VDC
Idling current: 3 A
Idling current when off: 0.02 mA
Consumption @ 14.4 VDC (Max Musical Power): 110 A
AMPLIFIER STAGE
Distortion - THD (1k Hz @ 4Ω ) A, B Ch: 0.05 %
Distortion - THD (100 Hz @ 4Ω), C (sub) Ch: 0.3 %
Bandwidth (-3 dB) A, B Ch: 4 60k Hz
Bandwidth (-3 dB) C (sub) Ch: 7 350 Hz
S/N ratio (A weighted @ 1V) A, B Ch: 100 dB
S/N ratio (A weighted @ 1V) C (sub) Ch: 87 dB
Damping factor (1k Hz @ 4Ω) A, B Ch: 100
Damping factor (100 Hz @ 4Ω) C (sub) Ch: 80
Input sensitivity: 0.3 5 V RMS
Input impedance: 15k Ω
Speaker-In sensitivity: 1.4 24 V RMS
Speaker-In impedance: 5k Ω
Minimum load impedance A / B / C Ch: 4Ω / 2Ω / 2Ω
NOMINAL POWER (RMS) A + B + C Ch @ 12 VDC,
THD 0,3%, 4Ω: 50 W x 2 + 120 W x 2 + 500 W x 1
OUTPUT POWER (RMS) A + B + C Ch @ 14.4 VDC, THD 1%:
5 Ch: 75 W x 2 (4Ω) + 140 W x 2 (4Ω) + 600 W x 1 (4Ω)
5 Ch: 75 W x 2 (4Ω) + 140 W x 2 (4Ω) + 1000 W x 1 (2Ω)
5 Ch: 75 W x 2 (4Ω) + 250 W x 2 (2Ω) + 1000 W x 1 (2Ω)
SIGNALS INPUTS / FILTERS
Inputs: Pre IN / Speakers IN
Outputs: Pre OUT Full Range
A Ch Filters (Full / Hi-Pass):
50 5k Hz (2 range) @ 12 dB/Oct.
B Ch Filters (Full / Hi-Pass / Band-Pass):
50 1k Hz (Hi) / 250 5k (Lo) @ 12 dB/Oct.
C Ch Filters (Full / Lo-Pass): 50 150 Hz @ 24 dB/Oct.
OTHER FUNCTIONS
Remote IN: 7 15 VDC - 1mA
Remote OUT: 12 VDC - 50mA
Fuse (Strip type): 100 A
Remote SUB volume adj.: (-50 6) dB
Speakers IN Turn-on (ART): Selectable
DIMENSIONS:
Max size (mm/inches): 220 x 470 x 58 / 8,66 x 18,50 x 2,28
Used, very good condition.
Comes with Bit In installed. Will also come with standard RCA input plate.
Purchased from Custom Sounds in Austin, TX.
$950.00
See attachments below.
[b
[/SIZE]
Old 07-19-2017, 07:05 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Someone else tell him, I tell all the new people..
Sent from my SAMSUNG-SM-G530AZ using Tapatalk
Old 07-19-2017, 09:02 AM
209native's Avatar
0/11 sssss1975
zero f$#ks for the rules....
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
The Following User Says Thank You to 209native For This Useful Post:
jigsizzle (07-19-2017)
Old 07-19-2017, 04:18 PM
SPANKYSPL's Avatar
0/11 ssssss243
From the looks of it, I am far from new here. Just took an extended hiatus. Something new I missed?
Old 07-19-2017, 04:20 PM
SPANKYSPL's Avatar
0/11 ssssss243
How about you? What rule change/revision/update did I miss?
Old 07-19-2017, 04:23 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Sorry killer, when I don't see a username and date in the pics for a product someone wants 950 dollars for.... Well, you get it.... Lol!
Old 07-19-2017, 04:27 PM
SPANKYSPL's Avatar
0/11 ssssss243
Ahhhhhh.....yes. Sorry, must have stashed that away since signing up 8 years ago. Rules, gotta revisit them every now and then..
Will update this evening..
The Following User Says Thank You to SPANKYSPL For This Useful Post:
209native (07-20-2017)
Old 07-19-2017, 04:28 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Appreciate you sir...
Old 07-20-2017, 04:58 PM
209native's Avatar
0/11 sssss1975
thanx for updating your pics its the best way to keep out the scamming [email protected] nice gear btw
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 07-21-2017, 12:36 PM
SPANKYSPL's Avatar
0/11 ssssss243
Thank you.
Audison Bit.One AtlasMick eBay 0 10-03-2015 02:11 AM
Audison Bit One wrench722 Head Units, Processors & EQs 0 01-24-2014 08:33 PM
Audison Bit One wrench722 Head Units, Processors & EQs 1 01-24-2014 02:37 PM
Audison bit 10 Audio4lyfe General Car Audio Discussion & Questions 2 10-27-2012 01:55 PM
