Rockford Fosgate T600-4 - excellent condition - Car Audio Classifieds!
Old 11-05-2017, 06:15 PM
0/11 sssss1122
Feedback Score: 23 reviews
Default Rockford Fosgate T600-4 - excellent condition
Power 600 Watt 4-Channel Amplifier | Rockford Fosgate ®
Number of Channels: 4
Rated Power: 100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
Total Power: 600 Watts
Dynamic Power: Front Channels
139 Watts x 2 @ 4-Ohms 0 degrees Res
236 Watts x 2 @ 2-Ohms 0 degrees Res
Rear Channels
140 Watts x 2 @ 4-Ohms 0 degrees Res
Bridgeable: Yes
Efficiency (average): 70% @ 4-Ohm
64% @ 2-Ohm
Crossover Controls: Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls: Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input: Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output: Low Level: 1 RCA pair
Power Input Connector: Block
Power Wire Gauge: 4 AWG
Speaker Output Connector: Screw terminal barrier strip
Speaker Wire Gauge: 8 AWG to 18 AWG
Heat Sink Type: Cast aluminum
Cooling: Convection
Remote Controls: Optional Remote Punch EQ (overrides built-in Punch EQ)
Visual Indicators: Power
Thermal
Protect
Circuit Topology Class: Class A/B
Frequency Response: 20Hz to 20kHz +/- 1dB
Shipping Weight: 12.00 Lbs. (5.44 Kg.)
Dimensions (HxWxL): 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
Excellent
$350 shipped
Old 11-26-2017, 12:20 PM
0/11 sssss1122
T600-2 and T600-4 are lowered to $300 shipped each.
Old 11-30-2017, 06:11 PM
0/11 sssss1122
PM reasonable offers, thanks.
Rockford Fosgate T600-2 - excellent condition edouble101 2-Channel Amplifiers 3 12-01-2017 02:56 PM
Rockford Fosgate T1500-1bdCP - excellent condition edouble101 Mono Amplifiers 1 11-22-2017 09:20 AM
Rockford Fosgate 800a2 excellent condition pontius 2-Channel Amplifiers 1 08-28-2013 07:51 PM
Rockford Fosgate T600-2 michigancapri92 2-Channel Amplifiers 14 05-09-2013 01:41 PM
FS : Rockford Fosgate T600-4 Great Condition skaraudio Multi-channel Amplifiers 1 06-19-2012 12:35 PM
