FS: JL Audio A6450 Multi-Channel Amp - Car Audio Classifieds!
Old 12-10-2017, 05:43 PM
0/11 sssssss12
Default FS: JL Audio A6450 Multi-Channel Amp
JL A6450
6-channel car amplifier # at 14.4 volts: * 70 watts RMS x 6 at 4 ohms (110 watts RMS x 6 at 2 ohms) * 220 watts RMS x 3 bridged at 4 ohms # at 12.5 volts: * 45 watts RMS x 6 at 4 ohms (75 watts RMS x 6 at 2 ohms) * 150 watts RMS x 3 bridged at 4 ohms # differential-balanced inputs # Advanced Rollback Protection System # variable high- and low-pass filter (50-200 Hz, 12 dB/octave) # switchable bass boost on ch. 5 and 6 (0, 6 dB at 48 Hz) # optional wired remote bass boost # Absolute Symmetry™ Class-AB amplifier design # MOSFET power and output stages # preamp-level inputs # speaker-level input with optional converter # 4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier # no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended # 18-1/8"W x 2-1/2"H x 9-1/4"D
Been installed since 2011, ran active speakers tweeter/mid up front and mono sub with no issues. Some light scuffs and nicks on the front as it was mounted under a seat. Works as expected without issue.
$150 shipped to the lower 48 to include tracking info upon payment and shipment.
Thanks,
Kevin
Old 12-10-2017, 11:39 PM
pickup1's Avatar
old guy
0/11 sssss1348
Looking for any trades.?
Old 12-11-2017, 08:56 AM
0/11 sssssss12
Sorry, not interested in trades at this time.
Old 12-11-2017, 08:03 PM
0/11 sssssss12
Photo required of username and date...
Old 01-17-2018, 04:09 PM
0/11 sssssss12
To The Top
Sundown audio component sets/multi channel amp lilmoss Wanting to Buy (WTB) 2 07-23-2012 03:59 PM
WTB multi channel amp Jokerr Wanting to Buy (WTB) 17 12-29-2011 08:27 PM
JL a6450 6 channel amp morning_wood Multi-channel Amplifiers 2 09-12-2011 03:41 PM
looking for 1200watt amp multi channel stampz2 Wanting to Buy (WTB) 11 08-05-2011 01:08 AM
wtb multi channel amp cisco479 Wanting to Buy (WTB) 14 10-20-2010 09:06 PM
