Jl hd600/4 plus free stuff! - Car Audio Classifieds!
Old 06-21-2019, 05:02 PM
0/11 sssssss12
Default Jl hd600/4 plus free stuff!
JL HD600/4 4-channel amplifer. Was going to use them with an sq system that I never installed so they've been sitting around. Also giving away for free 50sq ft of RAAM BXT II sound deadener ($175), 15ft of KnuKonceptz 4 gauge ($15), 13ft of Trystar 1/0 gauge ($25) to buyers while supplies last.
@ 4 Ω 150 W RMS x 4
@ 3 Ω 150 W RMS x 4
@ 2 Ω 150 W RMS x 4
@ 1.5 Ω 150 W RMS x 4
Bridged @ 8 Ω 300 W RMS x 2
Bridged @ 4 Ω 300 W RMS x 2
variable high- and low-pass filter (50-500 Hz 12 or 24dB/octave)
subsonic filter and output polarity control
removable power and speaker plugs
optional wired remote for level control
Class D amplifier design
MOSFET power and output stages
differential-balanced inputs eliminate noise from your vehicle's electrical system
speaker- and preamp-level inputs
preamp outputs
4-gauge power and ground leads and a 80-amp fuse recommended — wiring and hardware not included with amplifier
10-3/4"W x 2"H x 7-7/8"D
no onboard fuses — when installing multiple amps in a system, an additional 80-amp in-line fuse between the distribution block and the amplifier is recommended
Very good and in original packaging. Selling all of my equipment.
$400 shipped.
Tags
4 channel, amp, amplifier, hd600/4, jl audio
