FS: Old school Goodness!!! - Car Audio Classifieds!
Old 12-25-2009, 06:43 PM
newarkbeast973's Avatar
0/11 sssss7810
Default FS: Old school Goodness!!!
MTX thunder 4300x
-Patented PWM MOSFET Switching Power Supply (#5,598,325)
-Class A 100% Discrete Driver Circuit Topology
-High Powered Transfomers
-N-Channel V_FET Output Stage
-Doubles Power into 2 Ohms
-Bridgeable, Multi-Channel Circuit Design
-1% Tolerance Thru Hole Metal Film Resistors
-Real Time Computerized Protection Circuit
-Acoustically Seamless Turn-on/Turn-off (i.e. no noise)
-Built-in 18dB/Octave Defeatable Crossover Variable 50Hz to 200Hz, HP or LP Selectable
-Alternate Output with Complementary 18dB/Octave Defeatable Crossover Variable from 50Hz to 200Hz, Selectable (2300X ONLY)
-Front and Rear Summed Line Level Outputs (4300X ONLY)
-Continuous Adjustable and Defeatable Thunder EQ Bass Enhancement Circuitry, Centered at 40Hz
-Low Level Inputs
-External Bass Control Port for easy Bass Adjustment via Optional EBC Unit (2300X ONLY)
-Front and Rear Individually Adjustable Input Sensitivity (4300X ONLY)
-Left and Right Individually Adjustable Input Sensitivity (2300X ONLY)
-Gold Plated, Heavy Duty Terminal Block Type Connectors
-2" Maximum Height for Easy of Installation
-Patented Split Shield(TM) Bottom Plate Design (#5,521,792)
-Patented Nylon Insulated Iso-Feet(TM) (#5,521,792)
-Bold and Aggressive Heatsink Shape and Size
4300X Specs:
RMS Power measured at 12.5 Volts DC:
37.5 watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd
mechanically 10/10
cosmetic condition- 7/10
the edges are scratched up!
$150 OBO shipped!!
New build coming soon!!
Old 12-28-2009, 03:14 AM
0/11 sssss7810
ttt
Old 01-28-2010, 09:35 PM
0/11 sssss7810
TTT!!!
Old 01-30-2010, 06:25 PM
0/11 sssss7810
make offers fellas..
Old 01-31-2010, 11:33 PM
0/11 sssss7810
BUMP
Old 02-06-2010, 07:16 PM
0/11 sssss7810
I know someone is looking for a nice SQL 4 cha amp!!!
Old 02-07-2010, 07:21 PM
0/11 sssss7810
BUMP!!!
Old 02-08-2010, 08:22 PM
0/11 sssss7810
TTT
Old 02-12-2010, 11:33 AM
0/11 sssss7810
willing to trade for some deadner as well!!!
Old 02-16-2010, 08:20 AM
0/11 sssss7810
no one needs a good 4 cha sql amp?
[SOLD]Autotek mean macince model 99 old school goodness on1wheel01 2-Channel Amplifiers 13 01-07-2010 04:31 PM
FS:12" old school beyond audio goodness! snoopysnooper 12" Subwoofers 7 11-18-2009 12:30 PM
Old School Goodness HiloDB1 General Car Audio Discussion & Questions 0 08-08-2009 05:33 AM
Opinions On This Car - Old School Goodness worstenemy453 Off Topic Chat 49 05-02-2009 10:58 PM
FS Orion 225 HCCA old school high current goodness! audionutz 2-Channel Amplifiers 2 11-25-2008 07:28 PM
