DLS Ultimate A5 - 3ch Amplifier - Car Audio Classifieds!
Old 10-31-2008, 12:23 PM
0/11 ssssssss9
Default DLS Ultimate A5 - 3ch Amplifier
$325 shipped
I own 6 DLS amps and need to part with a few. Bought the amp as seen and would be mint if it did not have the bends.
  • RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
  • Mode : AB
  • Number of channels : 3
  • Output power in 4 ohm : 2 x 85 W
  • Output power in 2 ohm : 2 x 100 W
  • Mono channel, ouput power in 4 ohm : 300 W
  • Mono channel, output power in 2 ohm : 500 W
  • Mono channel, output power in 1 ohm : 780 W
  • S / N ratio, A-weighted : > 100 dB
  • Damping factor : > 200
  • Input impedance : > 10 kohm
  • Input sensitivity, variable : 0,2 - 7 V
  • Filter, front channels : Highpass: 50-125 Hz
  • Filter, mono channel : Lowpass: 40-90 Hz. Subsonic: 25 Hz
  • Phase shift control 0-180 degr. : Yes
  • Remote sub level control with phase control : Yes
  • Terminal for external cooling fan : Yes
  • Dual DC-inputs : No
  • Current draw, idle : 0,5 A
  • Current draw, maximum : 90 A
  • Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Alpine CDA-9887
Alpine PXA-H701
Alpine RUX-C701
DLS Ultimate Noblium 6.2"s
Illusion Audio ND 8"s
Resonant Engineering XXX 12"s
DLS Ultimate A3
DLS Ultimate A4
DLS Ultimate A6s
Ultimate subwoofer ideas bumpin buick General Car Audio Discussion & Questions 31 12-30-2009 10:30 AM
DLS Ultimate A3 Amplifier Twin Mono frkkevin Mono Amplifiers 4 11-01-2008 12:21 AM
USACi Sanctioned Event - Ultimate Pit Stop ~ LA MARQUE TX ~ 11-02-2008 CACO's Car Show Bot Car Show Feeds 0 10-20-2008 02:17 AM
The ultimate street racing PWND Patrick Simmons Off Topic Chat 0 08-01-2008 02:37 PM
